Some more from Gigabyte UP5 Memory LN2 2.1v 7-11-7-28-90@1354 6.16.797
http://s12.postimage.org/pgqzdzaa5/qqqq.png
^outrageous:eek:
Please ban bullant,he is killing us :( :D
nice one Bullant!
@Splave: Don't think background is neccessary..But maybe taking more subs into the new list?
@Don: As sign of civility i wanted to ask honda, otherwise someone could think one's hijacking this thread, no matter who will update it in future. AND: Sometimes the easiest solutions are the best, too :rofl: but i also did not get that :D
I don't see a point in having a new thread since this one has way too many useful information to let it die.
Refreshed first post would be sufficient, I can do / keep doing that, given rights.
@Bullant Still using 2000C6 PIS? Makes me feel better knowing my 6x2GB of these are rotting in my drawer :rofl:
I've updated the first post with all the scores that were posted after the deadline. Unfortunately many great scores were not posted in the correct format, if your score is missing please repost and I'll add it.
Thanks guys ,
@ websmile,yeah man this run was with the g skill C6 2000 Pi mems -85 and fresh OS
@Don Dan,I just need to write the correct format to my screenshot ?
Wow look at the list!!! Its alive...... I had no idea there were so many.
Top bit of work updating Don Dan thanks.
I'll fix up or re run my entrys soon.
### Edit ###
Fixed up post 1251
http://www.xtremesystems.org/forums/...=1#post5166922
Thanks Don :)
hm want to play again soon..if something goes wrong, i will post the 469 in correct format, promised :D
what about Sam's suggestion to separate air/cold or chips with different colors?
fixed format and time
PSC
l0ud_sil3nc3 - 6:17:985 - 108.7x46 - 1303.5MHz - 7-11-7-28-98-1 - Asrock Z77 OC Formula - G.Skill RipjawsZ 2400c8/PSC - 1.96v - cpu LN2 / memory LN2
BBSE time here. . .
l0ud_sil3nc3 - 6:18:422 - 108.6x46 - 1303.5MHz - 8-11-7-22-88-1 - Asrock Z77 OC Formula - G.Skill RipjawsX 2133c8/Elpida BBSE - 1.87v - cpu LN2 / memory LN2
Yes, please use the format from the first post:
Username - time(mm:ss:ms) - multi x blck - ramspeed(xxxx.yy)mhz - ram subtiming(tCL-tRCD-tRP-tRAS-tRFC-CR) - Motherboard model - ram info/chipset - vdimm - ram cooling
Please don't edit your old posts, just repost the submissions you want to add to the first post in a new post.
You're welcome! :)
You're welcome! I've added your score because it's the best one, I just need the Vdimm you used to complete the entry. :up:
Let me know if you guys want to use different colours.
Added.
Fixed format
bullant - 6:16:797 - 104.2x48 - 1354.2MHz - 7-11-7-28-90-1 - Gigabyte Z77X-UP5TH -G.Skill Pi 2000c6 4X2Gb/PSC - 2.1v -CPU SS -30 / Memory LN2 -85
http://s11.postimage.org/bto39q3yb/qqqq.png
Done.
Thanks Don Dan,and thanks for your time taking over the thread
newwww thread :) http://www.xtremesystems.org/forums/...Geee-Challenge!
[QUOTE=angoholic;5168706]
Yeah man look forward to you pushing some more,I should have some more LN2 in a week and will keep pushing
didnt notice don dan was still going with this, I'll delete the one I made
Little bit more different memory's G skill Pis 2200 C7
bullant - 6:16:734 - 104.2x48 - 1354.3MHz - 7-11-7-25-90-1 - Gigabyte Z77X-UP5TH -G.Skill Pi 2200C7 4X2Gb/PSC - 2.15v -CPU SS -30 / Memory LN2 -100
http://s18.postimage.org/x6lmx8xzt/ytttt.png
Note,I did manage to do this same run with tWCL6 but only got to 20 loops tho
Had another go today,managed to get tWCL 6 to pass but only little improvement,think i blew waza on this one
bullant - 6:16:704 - 104.2x48 - 1354.3MHz - 7-11-7-28-90-1 - Gigabyte Z77X-UP5TH -G.Skill Pi 2200C7 4X2Gb/PSC - 2.15v -CPU SS -30 / Memory LN2 -110
http://s4.postimage.org/uy3ld1tvx/eeee.png
One more
bullant - 6:16:656 - 104.2x48 - 1354.3MHz - 7-11-7-26-90-1 - Gigabyte Z77X-UP5TH -G.Skill Pi 2200C7 4X2Gb/PSC - 2.15v -CPU SS -30 / Memory LN2 -120
http://s11.postimage.org/4ej6ubn03/sssss.png
He he looks like you having a ball over there chipping away at your time :up:
After your last .704 post I was going to ask if you had played with tRAS/tRFC now you running tCWL 6 to see if you could squeeze it a bit more & figured na... reckon you know what you upto :D
