Most of the chips can do around 4.6 - 4.8 and that's about it :) It's just the lucky ones being able to hit 5Ghz or more.
How do you take a cpu back and exchange it?
Another 2600K 3101A201...*A1181 max 53X. Still try to find mhz wall on air
Edit: this one is too hot with crappy A50 air
Put under SS...max multi 53X but can go 5.5Ghz with BCLK and lower Vcore (comparo to L0 batch)
Kinda weird cpu
http://img97.imageshack.us/img97/586...nshot020mb.jpg
What is your opinion so far on the batches that start with a 3?
I have a batch 3103B307 that does 56x but gets stuck at the windows logo screen.
At 1.55V
51x= ok
52x= ok
53x= ok
54x= ok
55x= ok (unstable but boots in and can do normal things)
56x= Freeze at windows screen even at 1.6V (worth it to try more to see how far it gets? I'm on air!)
http://i595.photobucket.com/albums/t...202/online.jpg
3103B375 4.7ghz 1.4v
The latest batch of South Korea ;)
Batch : L107A719
MAX : x53 1.45v
http://www.playwares.com/xe/files/at...8/IMG_3201.JPG
http://www.playwares.com/xe/files/at.../screen000.jpg
And my best 2600k cpu
Batch: L048B284
http://cfile10.uf.tistory.com/origin...4D911F03241159
:shocked: X53 @ 1.45v? What the hell?
That's gota be a record...
Is HT on or off at X53?
Thank you.
NameGT: Do you know the default VID for that CPU (at 3.4 ghz?), and the default VID (when set to 100x50)?
1.15v? I Think this is not the VID, but the voltage monitoring? No one has had a VID this low on a 2600k (at 3.4 ghz).
The VID is the "target" voltage shown in the BIOS, next to your "Auto" or "manual" voltage selection. This is not the "current voltage reading" actually going into the CPU, but the "target VID." The current actual vcore the CPU is using (power wise) will ALWAYS be lower than the VID, unless you are using loadline calibration (at high levels).
You can also see the VID by starting the computer into windows and using realtemp 3.67 (EIST/speedstep/C3/C6 must be disabled).
For example, in the BIOS, to the left of where you can choose your manual voltage, you will see a VID (might be labeled "Voltage" or just "Target").
1.15v is too low of a VID for 3.4 ghz for a 2600k. There was a survey of VIDs at 3.4 ghz, and the lowest possible one shown was 1.21v. I think the lowest possible VID for 3.4 ghz is 1.20v, and the highest is 1.27v. 2500k's I think may have lower VID than 2600k's.
In case I'm wrong, then this is the first 2600k I've ever seen that has a VID of 1.15v.
If the VID is really 1.15v at 3.4 ghz, then the vcore in health monitoring should be almost 1.13v or lower, and in windows, if you run prime 95, it should be 1.0v or lower.
Good point.
Try that and check the VID again for me. I know it won't be 1.15v...that's a 2500k VID (for 3.4 ghz)....
Without the many encouragements I've received, I may have stopped awhile back. Too bad the local MC cannot allow CPU purchase (same model) within 14 days. I'm gonna rest awhile until I see a new batch then I may do it all over again. :yepp:
jcniest,
I got lucky with my second 2600k, but some people had to go through over 50 of them before they got a decent clocker, and hundreds before getting a X56-X58 !
Even then, my max multi is either x53 or x54 (X49 with PLL disabled; X54 restarted on the XP splash screen, but it didnt freeze...so perhaps it needs more vcore, but I only tried 1.50v with LLC1).
You're not alone, my friend
You want to see bad luck?
I haven't won a SINGLE virtual currency gun in Crossfire, from crates (a FPS game), or from AVA, for ages. I've spent so much in game money on crates...I have much worse luck...and I can't even sell what i lost like you can, to try again...
sounds like your microcenter blows hard, the closest one to me (santa clara) isn't as cool as others I have been to, but I have bought one cpu every time I have gone, and I was never told of this lame policy that your store has. Two of the locations I have been to have even sold me more than one cpu in the same visit:D
Depends on the CPU. I'm sure I can do it at 1.455v BIOS without a problem (1.416v-1.428v load). Not sure about LinX though, don't really care about LinX.
I think VID doesn't mean anything :shrug:
My VID @ 3.4 is 1.25.
But I can run linx @ 1.368v 5Ghz and @ 1.416v 5.1Ghz. It scales great with vcore :D .
Never seen blinking cursor, but I get stuck @ windows logo with 56x , I've run w1024 and spi32Mb @ 5.5 with 1.6v, on wc
There was a survey that showed that on the AVERAGE, most lower VID chips had higher multiplier walls than higher VID chips, and I believe there were more dud high vid cpus than low. However there were always exceptions either way.
How hot does your CPU run at load?
5GHZ hot babe :D
http://img703.imageshack.us/f/stablek.jpg/
