Feser one black :)
Ty guys!
ey syc nice rig you got there! Congratulations ;)
There wasn't any problems with that Feser ? No gunk in blocks or flying in res?
HAF 932
http://farm3.static.flickr.com/2437/...a1c6efb3_b.jpg
i7 920 @ 3.6GHz ~65C (Prime95) with XSPC Delta V3, RS240, XSPC Dual Bay 750lph
[img]http://farm3.static.flickr.com/2772/4098441623_e97059a90a_b.jpg[img]
Powercolor 5870 LCS ~50C (Furmark 1.7), RS120, XSPC Single Bay Pump/Res
http://farm3.static.flickr.com/2573/...d3a75330_b.jpg
Looks like an EK nickel plated block
http://farm3.static.flickr.com/2757/...1496597b_b.jpg
These cards were easier to get hold of than air-cooled 5870s, only a few in the UK AFAIK and I think we have them all.
http://farm3.static.flickr.com/2772/...7059a90a_b.jpg
USFORCES, how could you possibly do any work at that desk? You must spend all your time staring at your rig!
I have always wanted to do that! If only you had a build log.... hrm....
nice rigs all around guys!
and gals!
USFORCES that's awesome, i regret buying a new case now, should have just bought a desk lol
Internals to messy and dirty to show right now :P
http://i295.photobucket.com/albums/m...2/DSC00325.jpg
http://i295.photobucket.com/albums/m...2/DSC00326.jpg
USFORCES
Outstanding work, man :up:
Thank you guys!!
I love that desk, so awesome.
Did a bit of mucking around with my case, mounted my spare MCR220 at the front of my case.
http://i240.photobucket.com/albums/f...r575/003-3.jpg
Old gear in new case, and water cooled.
http://i970.photobucket.com/albums/a...g?t=1258221584
http://i970.photobucket.com/albums/a...g?t=1258221693
Hard to see with my crappy camera skills, but there's a piece of purple glass in the bottom of the case, matched with purple noise blocker fans, now I just need some purple water.
nothing special bought new tubing
http://img517.imageshack.us/img517/2121/p1100006.jpg
http://img197.imageshack.us/img197/6144/p1100011b.jpg
Finally got my extra 120mm rad in, and a good oportunity for a rebuild.
Decided on a few improvements to what is basically my first w/c rig.
Installed a coolant temperature sensor, flushed and swapped coolant (the cheap anti-freeze I was using was nasty stuff and started to clog up my CPU block)
Now I got some Fezer pink and some UV anti kink stuff which has kinda pimped it up a bit, but not nearly like the meticulous work of some of these people!
Decided to remove the cumbersome M2F heatsink assembly to get lower nb temps, and it seems to have worked well, although this is at hte cost of slightly higher nb temps. I'm thinking of getting another fan for the other side of the internal radiator which might help the air get past it a bit better. All in all the layout seems to work well. The only niggle is intaking air via the smaller rad which might bump up temps a touch.
http://i194.photobucket.com/albums/z...DSCF0670-1.jpghttp://i194.photobucket.com/albums/z...h_DSCF0713.jpghttp://i194.photobucket.com/albums/z...h_DSCF0719.jpghttp://i194.photobucket.com/albums/z...h_DSCF0699.jpghttp://i194.photobucket.com/albums/z...h_DSCF0711.jpg
@Weevil: Nice Blue Ring! Ive got the same case but never thought of water cooling:rolleyes:
You put your DVD drive into the lowest slot to make the top radiator fit, right?!
Love it too, mine even is powdercoated black:D:p:
http://img211.imageshack.us/img211/9371/dsc0651d.jpg
http://img402.imageshack.us/img402/3200/dsc0395g.jpg
http://img402.imageshack.us/img402/6218/dsc0410p.jpg
http://img689.imageshack.us/img689/3092/dsc0649v.jpg
http://img402.imageshack.us/img402/3632/dsc0399e.jpg
http://img402.imageshack.us/img402/787/dsc0413x.jpg
