Hey Mass, here's one with better efficiency, despite running Windows 7.
http://img.photobucket.com/albums/v6...hots/18501.jpg
With XP i'm sure efficiency can be improved.
@air, foxconn destroyer
http://img187.imageshack.us/img187/15/pi4250ms1.th.jpg
i can't adjust the NB Frequency:shrug:
raiderman what gadget is that you have in the top right corner, you know the one that sais Phenom II.
ive got a lot on my desktop for that :up:
Ok here the best i been able to do so far running 64bit-vista
CPU CACVC AC 0848FPMW I ran 2 hours of prime that good for get on the board right ?
Particle heres one for the board on DI.
http://valid.canardpc.com/show_oc.php?id=507952
my 720BE is dead now lol
here's why
http://www.xtremesystems.org/forums/...d.php?t=217888
Wow that was quick :( I thought I killed mine tonight as well, 1.9vcore trying to crack 5.1g, I need more cold less volts.....
Refused to post for like 5 mins, I need to retest it on air see if it caused any damage.
I thought with all IMC you were supposed to bump core voltage and probably NB voltage to combat if you will high DDR voltage.
finally got some time to push my 940be a little bit (0850epdw)... didnt get any 3dmark yet but that will be to come, i really need a better bios, this new one will crash w/ any nb multi adjustments and is more flakey overall so im using an old bios (same one that took my 9850 to 3.7ghz valid, 3.5ghz 3d06 stable =)
max valid 4.375ghz @ 1.638v xp32(for tonight... im comin for that top air spot lightman!)
http://valid.canardpc.com/show_oc.php?id=508157
little pi action with my crummy ass ram and my locked nb multi =) xp32
4.25ghz @ 1.638v, nb @ 2317mhz, ram @ 1030mhz 5.5.5.15.26
http://i70.photobucket.com/albums/i8...titled-1-2.jpg
edit: did a little push pull w/ 2 2000rpm fans on my hs, passed occt @ 3840mhz with 1.538v in vista64, 46c max temp =) - im gonna run 1 more run before bed, do i keep same volts and go little bump maybe 30-40mhz or more v's and go straight for 3.9 lol hmmm
http://i70.photobucket.com/albums/i8...2/occt3840.jpg
im not sure what ambient was exactly, its usually around 71-72f in this room so i cracked the window :p:, my hd temp, tmpin0 temp, and tmpin2 temp were all about 5c cooler than with normal ambients so id guess around 65-66f :shrug:
hello =)
first at all, i`m new here, so if there are formal mistakes, sorry for it ;)
all these benchmarks are on air (Thermalright Ultra-120 eXtreme)
instable:
Cinebench R10: 16479CBs
http://img3.imageshack.us/img3/9024/16417vk6.th.jpg
SuperPi: 17.858s
http://img155.imageshack.us/img155/7...erpitm8.th.jpg
http://valid.canardpc.com/cache/banner/499154.png
stable: 220x17,5 3850Mhz @1,52vCore
http://img26.imageshack.us/img26/5453/siegwz8.th.jpg
http://valid.canardpc.com/cache/banner/508569.png
Lets see what this can do
http://img518.imageshack.us/img518/2272/scanio0.jpg
thats what ive been waitin for! i know you'll treat that chip right :D
definately keep us posted on that chip, inquiring minds would like to know :p:
check this out hondaguy,,, so friday some friends and i head down to the Lakefront Brewery here in milwaukee and go on the brewery tour. its nice, 5-10 bucks you get to see how the beer is made and you get some free beers... anyways, im just walkin along on the tour and see this off to the side :ROTF:
http://i70.photobucket.com/albums/i82/mrjohnson2/r.jpg
So much for my copywrite protection......Thats tooo funny, I know I like my beer also..lol......So what time are we heading down there this friday?, Or are you just trying to butter me up for this chip :rofl:
Pop'd in this chip on friday but never really had a chance to overclock it but did get a chance to do some, just did a stablitiy test through AOD for 45 mins....
http://img11.imageshack.us/img11/293...901apmwwa2.png
I sure like those volts at that clock!
Here is CPUZ 1.525 volts..........Crazydiamond: this chip has your name on it :D
http://valid.canardpc.com/show_oc.php?id=508796
http://img152.imageshack.us/img152/9969/73263370is1.png
