Corsair ddr3 1600mhz only showing 4gig
You might remember a previous post when i had problems getting above bclk 172.Well i have a new i7 920 which booted straight away @180!Anyway i have another strange problem.In the bios all 3 channels are showing for the memory but only 4096 is displayed at post:mad: ,when i booted into Vista x64the o/s is only showing 4gig.If i look at cpuz it is showing 6gig and triple channel.:shrug:Anyone else had this problem?
If have done the following.
Reflashed and cleared cmos
Reloaded bios defaults.
All settings @ stock (when i first installed the cpu i used dram v1.66 and no more than 1.275 on qpi/vtt to test bclk 180)
Default volts:
cpu 1.2
dram 1.54
qpi/vtt 1.175
Re-seated the memory
swapped the sticks around
tested each stick in ddr3_1 slot -each test displayed 2gig
tested dual channel in dd3 3_1 and ddr3 3_3 -displayed 4gig
with all three channels only 4gig is displayed on post.
The memory appears to be ok.
Update on triple channel problem.
Its looks like i have found the problem.One of the pins at the bottom of the socket 1366 was slightly bent:eek: .Not sure how i carefully put the cpu in and it only goes one way!After bending it back in postion (not easy used a small needle pinhead) its posts with 6gig.
