http://61.220.123.253/cpg/albums/userpics/10001/350.JPG
fx53 socket OC 350Mhz
use K8N neo2
:banana:
johnnyliu3377
use K8N neo2
:banana:
johnnyliu3377
http://my.so-net.net.tw/johnnyliu/MS...-2.5%2032s.JPG
fx53 socket OC 320Mhz
use K8N neo2+A-data DDR566 5-3-3-2.5
:banana:
johnnyliu3377
i am new to this site so please excuse my lack of knowledge i can oc my rig fx53 sk8v koolance cooled to 2712 mhz here is my am3 score to prove it i dont know how to take screen shots so this is the best i can do:
http://arc.aquamark3.com/arc/arc_vie...run=1488406520
score 73,825 am3
14,008 3d03
29,582 2001se
welcome jon. screenshots are easy. just hit printscreen on your keyboard then open photochop or paint and use the paste command. then compress to your liking.
btw nice rig and scores.
finally got round to opening up my aopen 530psu. 3.3volt rail at 3.53volts and crocodile clipped to the memory capacitor. sp948u heatsink with 80mm fan. memory at 2t command rate unfortunately
edit for full codes:
ada3700aep5ar
caabc0417tpmw
9556722d40053
sadly not 24/7 stable... but the memory only gets 2,72v instead of 2,8... damn it!
http://manner83.bei.t-online.de/bild...i_28.07.04.gif
TM30 try to get better RAM, those timings are killing ya!
really ? where is the problem ? the 4-4 i think? but i am happy to see it at 260Mhz... because i did have so much bad luck in past time..
ok here we go... better timings, but not a better result... (EB's)
http://manner83.bei.t-online.de/bild...i_01.08.04.gif
this is me playing with a new Mobo..
Asus A8V Deluxe (completely stock)
Athlon64 3500+ S939 CBAUC 0420
OCZ PC4200 EL at 2.8V Vdimm
cooled with Mach 1
get the system cooled down a little better and should be benchmark stable ;)
This is a completely stock system except for the cooling system..
this is Better..
Asus a8v dlx (stock Mobo)
Athlon64 3500+ @ 279x10
OCZ PC4200 EL @ 2.5-4-4-7, 1:1, 2.8V Vdimm
Prometia Mach 1
Heres mine, not very impressive. 0416RPMW A64 newcastle
http://img61.exs.cx/img61/4199/amd_newcastle3.jpg
What'da ya guys think?
You should be getting maybe 2.65ghz @ 1.7V, I can get 2.6 @ 1.7 with a 3000+ newcastle but you have a higher stock clock.
Trying to get a stable speed on the crappy "overvolting" of the EPoX 8kDAj
This is with STOCK mach 1.
http://www.xs4all.nl/~famchow/A64_34...2M_2.85GHz.PNG
Asus A8V Rev 1 (locks do not work)
"BigToe" Beta bios
FX53 (939)
Corsair 3500 BH5 (1GB) 2,2,2,5
Mach II GT
So far got it to 3ghz (15x200) @ 1.824v using the multipliers alone having a few issues when you reboot but it seems perfectly stable otherwise. Will take some pics later on - super_pi is only 31 seconds though and I would have expected slightly quicker. Still experimenting though.
Yeah 4-4 are hurting your performance..
But now it's better ;)
3400+ @ 2.5ghz 1.6v
Weak OC at the time, but i'm only on air. Tried 2.6 but i need more vcore, it only reaches 1.7.
200FSBx12 1.5volt (normal-RAM[4 Lucas Lehmer iterations stable]
202FSBx12- 1.5volt (normal-RAM) fatal error
202FSBx12- 1.5volt (+0.1v-RAM) fatal error
202FSBx12- 1.5volt (+0.2v-RAM) fatal error
202FSBx12- 1.5volt (+0.2v-RAM)(+0.1 vddq) fatal error
202FSBx12- 1.5volt (+0.2v-RAM)(+0.2 vddq) fatal error
202FSBx12- 1.5volt (+0.2v-RAM)(+0.2 vddq)(vcc12 htt +0.1v)
Fatal Error
202FSBx12- 1.5volt (+0.2v-RAM)(+0.2 vddq)(vcc12 htt +0.2v) fatal error
:help:
This is kinda sick, had the ram on Cas 2, gonna try some more ram settings. Any OC experts who know what this can be?
btw: prime 95
What is even sicker i got 24000 exactly with 2.52ghz amd and 24408 in 3d mark 01 with 2.4 ....
what board Chris88? try 8-3-3-2.5 on the ram and try one stick. looks like your board doesn't like 2x512 memory.
I got Gigabyte K8NS MB. Gonna try with only one stick. And sure, i'll try anything. I just want my machine PRIME stable. Used 80$ on a Swiftech cooler so i'm gonna OC my CPU! :)
yay: i'm stable at 202fsb. Now i'm gonna OC this :banana: :banana: :banana: :banana:.. :D
My machine just turned itself off for no reason, and the screen flashed. Then i took out one stick of ram and it booted. Now i'm gonna try that OC and check if it's stable. Weird stuff!
phil stanbridge how did you get your mutiplier up to 15?
FX53 is not multiplier locked
MainBoard: Abit Av8
CPU: S939 fx53
Ram: Ocz pc3200 ver 2, platinum
Vdimm 2.8v
vcore 1.8v
By the way, the chip is Samsung TCCD, 0425 week;)
http://www.e04hardware.com/record/0817rec.jpg
Close to 3400+ 1MB @3GHz.
3400+ AX 512KB
CBASC 0413SPMW
Mach 1 R507
Vcore 1.9v
Vmem 3.38v
http://www.xs4all.nl/~famchow/A64_34...st_3.03GHz.PNG:banana:
