If i'm not mistaken the new bios is a microcode update that is needed for the penryn to function properly. i would flash if i were you. I am using it and it is fine so far. no issues.
I got a single Floppy but it has all the drivers on there...ICH9R and JMicron.
Ran RAID flawlessly since install.
Last night I swapped the DFI to the lesser PSU and Raptor in the TekTray and set up the Yorkster on the BMF set up and just now got around to hooking the DFI back up...
Thanks jimmyz. I just got that from Brother and will get right on it :up:
Yep
I'd read about it...and now I know about it.
It's a very strange thing IMO...
Cleared CMOS installed XP restarted Hung no POST
no POST, no monitor...just C1 code.
On starting from powering up I get 88 C1 25 26 then it shuts down and restarts automatically and I get C1 and that's it...
The only hardware I have changed is the Hard-Drive. I've tried three other hard drives.
CyberDruid , Try 1 stick of low voltage ram, after c-mos clear prefferably something with 667 spd works best for me. (i've had the c1 errortoo many times to count on this and the r600 board and neither one persisted after i swap to cheap ram to get into bios.) currently i use 4 x512 mb sticks and they never give me any issues since they boot at low voltage.
Luckily I have just that on hand :)
BRB
BTW I was able to get into BIOS...
the issue is hanging after POST...it just hangs..cursor blinking away
I tried 4 x 51 of G Skill 1.8V and got the exact same issue.
I can get into BIOS...but no matter what settings I try it make no difference...still hangs after POST...
Cut operations short to tweak Ram he heh:D Will post up more in a little while:)
DFI LANPARTY UT P35-T2R (BIOS 9/13/07)
INTEL CORE 2 DUO QUAD Q6600 KENTSFIELD 2.4GHZ 4M L2 CACHE
OCZ Flex XLC (PC2 9200) 5-5-5-18 2 x 1GB
ATI XT1950 XTX (CATALYST 7.8 @ 695/1098)
Auzentech XPlosion (BOOM HEAD SHOT!)
Areca 1231 ML {Intel IOP 341} ~ 6 ~ 250gb Hitachi Sata II Raid 6 ~2~WD 74gb Raptors ~ Raid 0 ~
Plextor 750A
SilverStone OP1000
Tuniq Tower 120
Code:>CPU Feature:
Thermal Management Control.......... - Disabled
PPM(EIST) Mode...................... - Disabled
Limit CPUID MaxVal.................. - Disabled
CIE Function........................ - Disabled
Execute Disable Bit................. - Enabled
Virtualization Technology........... - Enabled
Core Multi-Processing............... - Enabled
>DRAM Timing:
Enhance Data transmitting........... - Fast
Enhance Addressing.................. - Fast
T2 Dispatch......................... - Enabled
>Clock Setting Fine Delay Press Enter:
Ch1 Clock Crossing Setting......... - More Aggressive
DIMM1 Clock Fine Delay............. - Current[]
DIMM2 Clock Fine Delay............. - Current[]
Ch1 ControlFine Delay.............. - Current[]
Ch2 Clock Crossing Setting......... - More Aggressive
DIMM3 Clock Fine Delay............. - Current[]
DIMM4 Clock Fine Delay............. - Current[]
Ch2 ControlFine Delay.............. - Current[]
Ch1 Ch2 Common Clock Setting....... - More Aggressive
Ch1 RDCAS GNT-Chip Delay........... - Auto
Ch1 WRCAS GNT-Chip Delay........... - Auto
Ch1 Command To CS Delay............ - Auto
Ch2 RDCAS GNT-Chip Delay........... - Auto
Ch2 WRCAS GNT-Chip Delay........... - Auto
Ch2 Command To CS Delay............ - Auto
CAS Latency Time (tCL).............. - 5
RAS# to CAS# Delay (tRCD)........... - 5
RAS# Precharge (tRP)................ - 5
Precharge Delay (tRAS).............. - 12
All Precharge to Act................ - 4
REF to ACT Delay (tRFC)............. - 32
Performance Level................... - 6
>Read delay phase adjust Press Enter:
Channel 1 Phase 0 Pull-In.......... - Auto
Channel 1 Phase 1 Pull-In.......... - Auto
Channel 1 Phase 2 Pull-In.......... - Auto
Channel 1 Phase 3 Pull-In.......... - Auto
Channel 1 Phase 4 Pull-In.......... - Auto
Channel 2 Phase 0 Pull-In.......... - Auto
Channel 2 Phase 1 Pull-In.......... - Auto
Channel 2 Phase 2 Pull-In.......... - Auto
Channel 2 Phase 3 Pull-In.......... - Auto
Channel 2 Phase 4 Pull-In.......... - Auto
MCH ODT Latency..................... - 1
Write to PRE Delay (tWR)............ - 13
Rank Write to Read (tWTR)........... - 11
ACT to ACT Delay (tRRD)............. - 3
Read to Write Delay (tRDWR)......... - 8
Ranks Write to Write (tWRWR)........ - Auto
Ranks Read to Read (tRDRD).......... - Auto
Ranks Write to Read (tWRRD)......... - Auto
Read CAS# Precharge (tRTP).......... - 3
ALL PRE to Refresh.................. - 4
>Voltage Settings:
CPU VID Control..................... - 1.43125v
CPU VID Special Add................. - Auto
DRAM Voltage Control................ - 2.190v
SB 1.05V Voltage.................... - 1.070v
SB Core/CPU PLL Voltage............. - 1.55v
NB Core Voltage..................... - 1.57v
CPU VTT Voltage..................... - 1.50v
Vcore Droop Control................. - Disabled
Clockgen Voltage Control............ - 3.45v
GTL+ Buffers Strength............... - Strong
Host Slew Rate...................... - Weak
GTL REF Voltage Control............. - Enabled
CPU GTL1/3 REF Volt................. - 108
CPU GTL 0/2 REF Volt................ - 109
North Bridge GTL REF Volt........... - 112
Genie BIOS Settings:
Exist Setup Shutdown................ - Mode 2
CLOCK VC0 divider................... - Auto
CPU Clock Ratio Unlock.............. - Enabled
CPU Clock Ratio..................... - 8
Target CPU Clock.................... - 3550MHz
CPU Clock........................... - 444
Boot Up Clock....................... - Auto
DRAM Speed.......................... - 266/667
Target DRAM Speed................... - 1115MHz
PCIE Clock.......................... - 103mhz
PCIE Slot Config.................... - 4X
CPU Spread Spectrum................. - Disabled
PCIE Spread Spectrum................ - Disabled
SATA Spread Spectrum................ - Disabled
still with the yorky? so it is stopping on 96 or is it making it to FF? FF is attempt to boot iirc. i used to get a hang on boot on the r600 and if i raised the n/b voltage it would work the next try. did you flash the bios yet? if so you didn't use the yorky did you?
alot of times when i push ram too hard i get 88 or C1 on reboot but like the other person posted shutting off psu for 30 seconds or so fixes it most times.
i've gotta think it is the 45nm messing with it not the board.
No Yorkie yet, I only changed the HDD..not the CPU yet.
I was getting ready to when I encountered the issue..
Good idea about the NB volts. I will give that a try right now.
But just in case I contacted MotherboardPro about getting a replacement.
Thanks for posting up your setting Brother...that will come in handy in a few minutes :D
Some OCZ Reaper, voltage set at 2.10 in BIOS. CPU and NB GTLs on auto.
http://www.edgeofstability.com/misc/450x8prime.jpg
Whats you chipset voltage at John?
Mega Prime run.........But I don't think it ran long enough to be deemed stable:p:
Trying to revive the booard one more time. So weird how it will load an OS...but will not boot to an OS..
If I set it to boot from CD it does...
Ordered an Asus Maximus X38 to hold me over while I wait for the RMA on this loverly board to take place...
Unless I get lucky and don't have to RMA at all....
I'm having great success with these new Crucial Ballistix 8500's. First thing i noticed is that all 4 were able to post from defaults which was a nice change over the mushkin stuff :up:
currently have the 4x1gb modules running at 1112mhz at 2.1v, still needs some more tweaking though, havent played with fine delay with these yet
Edit: oh and timings only at 5-5-5-15 atm
Yay...managed to revive the board.
Found a Raptor and plugged that in the Jmicron header along with the SATA DVD and it is now booting like nothing ever happened...
Weirdness.
And it is FAST. Boots about instantly...love it.
Back to Folding :)
Here's a weird one..... When installing XP, if I select the ICH9R SCSI drivers off of the floppy, Windows doesn't reconize any drives. However, if I select the ICH8R/ICH9R drivers (further down on the list), everything seems to work just fine.
Correct. Same if I make the mistake of thinking somehow AHCI will work in Vista...
I found RAID worked well on the ICH9R for me.
Currently using the Jmicron for a single Raptor...could not get the ICH9R controller to act right for some reason.
VERY HAPPY to have my DFI back up...the few hours it was down seemed very long :p:
I agree, this board is awesome..... and it's the best one I have ever setup. Currently at 4GHz with a e6850 running the FSB at 500MHz, and it's rock solid.
The only problem I have encountered was when I setup the two 150G Raptors for RAID0 under the older BIOS, I would get an array error after defragging the array with diskeeper. The Array would still work, but I would see the error every time it booted up. I haven't tried it with the 9/13 bios yet.
I think I will probably get the Areca ARC-1210 RAID controller board to run the two arrays. I just need to know the length of the board to be sure it doesn't bump into the Southbridge water block.
Cheers!
Oops EDIT
It overhangs the PCIe slot about an inch and a half--so it will hang over the cooler on the second slot.
Check in CyberDruid....lets hear whats up with that Yorkfield and Beta Bios:clap:
Here are my OCZ 8500 SLI's @ 2.27v in BIOS
5.5.5.12.5.26.7. Phase adjust all Auto. A.13.11.3.8.A.A.A.4.5
NB 1.57v
CN :)
http://i106.photobucket.com/albums/m...903DMARK01.jpg
Is it safe to keep the NB core & VTT at 1.5v for 24/7 use?:confused:
@solarfall .....Hey man whats the verdict on you're end with the Cell Shock?
