someone knows CCB1E 0550VPMW in 165 ?
hey guys, got a question here. (Forum's finally back up, yay)
My core0 keeps failing at many different voltages.
Any way to strengthen it?
Cuz core1 is just fine with 1.4v for 2.7ghz, whereas core0 needs to go higher, and as of now cant do 2.75without getting even more voltage. Kindof annoying.
But, other than that, so far i had 2.6 at stock just fine, did prime it though.
Got 6hrs of priming at 2.7ghz 1.5v before i stopped it to go higher
did 2.75 at 1.525v (i think) last night, core 1 is still going after 7hrs, but core0 died after 3hrs
(0546)
This Opteron 170 0546XPMW is sweet
@2930mhz!!!
X1800XT stock heatsink @756/909
- undervolted ram from 2.097v to 2.034v (thanks SIOUX!)
http://www.fileshosts.com/DFI/NF4_SL..._11165_tnn.jpg
Thats the best I have ever seen eva for basic WC :toast: :fact: :clap:Quote:
Originally Posted by eva2000
I want it
is that Spi 32m / dualprime stable?? nice oc !! maybe the XPMWs are worth another try after all.......Quote:
Sweet bro! What is your vcore SET AT in your bios? If CPUz is showing 1.6 I'm guessing you are running something higher like 1.625?Quote:
Just got this (170 0546XPMW) yesterday...... Haven't had much time to play yet, here's a quick look. :)
2.6@1.35 - 2.7@1.45 - 2.8@1.55 - 2.9@1.65 and no temp issues. I'm not very comfortable running 1.65. :nono:
http://home.woh.rr.com/pcdoc1/images/Image1.jpg
got OEM 170 from newegg, bought ~22. december
CBBWE 0530TPMW :)
will try it, just to get some better thermal compound, this cooler master that comes in Hyper 6+ package is good for venice@2.7, i'm not sure how good it will be for this beast
wow... lucky!!!Quote:
Originally Posted by Ji 4Tze
i wonder.. when newegg is selling "refurbished" cpus.. where are these coming from? are they CPUs that people tried to O/C and didnt get good results so they sent them back?? the price is good but I worry that you will never receive a good clocker from buying a refurb CPU.
anyone have more info?
is 1.6volts considered "safe" for 24/7.
i do not think so. 1.6v is too high for 24/7 unless you are maybe using phase-change coolingQuote:
Originally Posted by situman
regardless of the cooling, that is on the verge of being overly risky. It's just about 20% over stock voltage.
I've been running nearly 1.7v if not 1.7+v actual for quite some time and haven't seen any sign of weakness after some brutal priming, benching, and various other 24/7 use.
I'll be more comfortable with it in a few weeks once chilly gets my unit shipped off.
I ran 1.62V 24/7 on air on my X2 3800+ for a few months. No problems
What mb was that on?Quote:
Originally Posted by IvanAndreevich
I run 2 instances of sp2004 when I test stability. Is that what you mean?Quote:
Originally Posted by FragTek
I was 2.6 @ 1.39v
Now 2.7 @ 1.48v
so far 6 hours 2 instances of sp2004
all stock hsf
Many other people have been receiving 0530TPMW from other retailers. They've still been clocking to 3Ghz I think someone just found them somewhere. :banana: I just received a Batch #47. :woot:Quote:
Originally Posted by LuckMan212
FZ1 it's 1.5 + 10% = 1.62v benching only
not at 2930mhz just benching hehQuote:
Benching only at 2930 LOL....you got a very good dual core Opteron :toast: :D
dogsx2
Ultra-D
Damn it my temps SUCK with this opteron! I am getting 51C dual prime @ 2.8 GHz 1.5V. That is 3C higher than I was getting with 3800+ @ 2.7 GHz 1.62V!
Uhh except now you have 2 cores in the same area? Not really seeing what the issue is, you're running a fairly good OC and the chip screams - 51C.. big f-u-c-k-i-n deal - at the end of the day, it still runs right?Quote:
And what's the point, he had 2 cores with the 3800+......Quote:
Originally Posted by i960
I have heard that Opteron tend to run warmer and I do not think 51C is bad at all for 1.5v ..my 165 when I push 1.52 bios vcore on DFI SLI ...get temps 51-54C..I can recall for sure but I know was around 52/53...It was not stable and my temps are so much better at 1.46 bios vcore ..load is 46/48Quote:
I have an OEM 170 sitting in unopened fedex shipping box from monarch..purchased on 12/27..shipped that day too..I heard someone else got another 0530 from them when he ordered on 12/23 but it shipped either 27th or 28th
I have refund rma as I canceled the order but it shipped anyway:slapass: (if I open it I am sure they will not accept the refund rma)
I just cant decide if it was worth opening and testing(I bet it is 0546 xpmw...I never have good luck getting a sweet stepping like 0530) which means I will hit probably 2700ish:rolleyes: ...I bet on my setup if I were lucky to get 2800 I would need 1.52-1.55v..which seems like alot and temps would probably range in 53-55C area..not sure it is worth the hassle of having to then unload my opty 165@2610 Prime 95 15hrs small fft stable
well you could sell it...to me.Quote:
Originally Posted by nealh
Was that 1.62 set in the BIOS or 1.62 reported by the sensors?Quote:
1.62 in the sensors must be something like 1.675 set in the BIOS on a SLI-DR.
