looks like lots of CABYE are just as overclockable as the CABNE....that's good! :D :D
i suspected as much, i was just wondering if you know what these various speeds obtainable could indicate :toast:Quote:
Originally Posted by eva2000
thanks nisco :D
I am about to build a new system with an Opti and as most here have a hard time finding a source. I have a small suggestion, maybe it wouldn't be a bad idea to start a vendor thread for opties with links and locations (USA, AU, EU etc)
Try compumusic, looks like they still have some stock of the CABYEs.
After a batch if 144 opterons vpaw i recieve tomorrow a opteron 146 week 36 VPAW :(.
Prolly going to sell it and reorder a new one opteron.
so....have anybody use their opty for gaming yet and how does it perform say compare to the FX? or are you guys still too busy overclocking the beast? :D :D all the benchie are fun but it would be nice too to see how they perform in BF2, UT2004 and whatnot. ;)
ok I did the gamble and bought a CABYE 148 :)
Couldnt find a CABNE so this was the best...
Should be here by wednesday !
Maybe temps are holding you back? Try reseating your HS, changing your HS (XP-90 is doing me well), and/or removing your IHS?Quote:
Originally Posted by wadec22
Originally Posted by ben805
Yes Ben, Been running my 148 solidly for about a week now @ 3.363GHz fully stable in BF2, FEAR and Black and White 2. In BF2 the framerates improved a lot more than I expected compared to my old FX-55 on air. Even with only a stock X850 the framerate is usually bumping the 100 fps limiter. :toast:
AWW YEAA!! glad to hear man.....do you still have the IHS on? hopefully my 148 can do 3.2~3.3 on phase change too, if it does then I'm going to let my X2 step aside for awhile :D :D can't wait to try it on BF2 and FEAR :toast:Quote:
Originally Posted by HermS
Still have the IHS on, this chip is too nice to be risking accidental damage. Will be really interested to see how yours performs on a PCICE phasechange! Good luck with it.
got mine!
OSA146DAA5BN
CABNE 0530APMW
batch 120 (last 3 digits of 3rd line right?)
A little expensive considering a $15 ground shipping charge.Quote:
Originally Posted by Confusion
In any event, they just sold out.
www.monarchcomputer.com
They have 146 148 150 152 165 170 175 socket 939 opterons ALL in stock as of 1pm MST October 17th. I just ordered a 146.
Where did you bought it? :DQuote:
Originally Posted by el rolio
Use part number to search site, I did not find them in the appropriate section.Quote:
Originally Posted by Runner
It's actually 4 last digits. Though, I guess Optys don't have nÂș's over 1000.Quote:
All I did to find them was type in Opteron 939. To find the 146 though, I had the search for it bookmarked :) along with about 15 other vendors I was prepared to buy from.
direct link scroll downQuote:
Originally Posted by 75sausage
If only somebody had the 144 :(. The 146 at Monarch is too expensive for me :mad:
eWiz. Though they're available now at Monarch too, as several people have already discovered. ;)Quote:
Originally Posted by xforce
Thanks. The chip is for a 24/7 rig. It's running very stable right now at 3GHz in my steel case.Quote:
Originally Posted by xenolith
Thanks for posting that runner.
:toast:
I scooped up a 146. Now we just have to hope they aren't the new "grbge" stepping.
No problem, and totally agree on that "grbge" stepping hehe, hopefully though monarch got a first batch.Quote:
Originally Posted by gbomb944
Looks like they are the new packaging and I'm pretty sure the early ones will be in the old box. I was seriously thinking of getting one of 148's from ewiz just because the cabye's seem to be guaranteed 3ghz pwnage, 3.? on phase. I figure it's bound to do 2.7 or 8. OC'ing is luck anyway unless you want to buy chip after chip an pray for a good one.
Looks like there's a 0.08 to 0.10v vcore difference between memtest and windows right now for each stage of oc listed at http://i4memory.com/showthread.php?t=1536.
At 2808mhz at 1.488v there's 33-34C idle temp and 43-44C load temp from 6+ hr cpuburnin max heat load running. MaxTcase temp this cpu is rated for is 57C. And not sure if it's correct but CBI reports thermal rating is 67W ???
http://www.fileshosts.com/DFI/NF4_SL...n_10hrs_tn.jpg
So with my 28C room ambient temps water cooling C/W
Total watts = (((1.488/1.36)^2 x (2808/1800)) x 67W) = 125.12W
Delta (between cpu load and room ambient) = 44.5C - 28C = 16.5C
Delta (between cpu load and cpu idle) = 44.5C - 33.5C = 11C
C/W = 16.5C / 125.12 = 0.1318 (assuming 67W rating is correct)
Memory wise it's fairly similar on mem controller to my FX-57, as 2x 256MB Gskill PC4400LE max windows superpi is around 322mhz 2.5-4-3-6 at 2.9v.
Dividers do complicate the oc'ing somewhat especially on 623-2BTA bios like 623-3 bios it doesn't like preamble set past 6.5ns as pc won't boot. Same happened when testing 2x1GB Crucial Ballistix PC4000 Tracer and Patriot PC3200LLK with 623-3 bios. 704-2BTA allowed my 2x1GB to use looser than 6.5 preamble though.
Then again with Swiftech G4 Storm waterblock probably need to remount the block a few times to get right clocks as my FX-57 between mounts differed in max oc from 3014-3120mhz!
Man wish i had a CABNE :(
edit: whoops forgot to plug the FDD power cable back in... probably won't make that much difference i don't think though
