Yea finally i got the Ultra volt moded and installed the TR-HR-03-Plus with a Delta 120x38 220CFM= Great overclocks on that Ultra :D
Thanks , good luck with the HR03-R600 ;)
and no fan grill on the Delta ? :eek: :eek: :eek:
I have 2 of those 220CFM deltas ,1 for the TR-120-Ultra eXtreme - 1 for the TR HR-03 Plus, i dont use fan grills , im very carefull with those and only use them while benchmarking , it is kind of scary actually and I should play safe and buy some fan grills , thanks for the advice.
Good day.
Even a Delta 120mm at 2000rpm will take a sizable chunk out of your fingernail... it did mine.
HR-01 Plus bro. tommy hewitt works with thermalright advertising i guess. poisoning me with these images again and again. Nicer base on the HR-01 Plus hope the mounting will be tight. Show the whole thing setup one you are done bro.
Yeeehaa, 7-8°C better than the HR-01 :D
http://www.abload.de/img/dsc01000ux3.jpg
did you really have to uncover the fan for the PSU bro ?
Yes :p:
very nice :D what kinda camera are you using?
HR-01 Plus.:slobber:
Do we get the fan clips with the retail one and same mounting h/w as the IFX?
Nice pics.:up:
And sorry for the O/T but can you help me pick a cheap standby cooler for my 939 X2 coz as of now the ultim90 is just short of the Ultra120 Extreme pricewise and i don't find it vfm.
I will buy a good cooler with my new quad rig.
Which one is better with a fan- Ultra90 or HR-01?:confused:
With the ultra90 i can use only 92mm, with the HR-01 i think i can use 92 as well as 120mm.:p:
Yeah, you will get the fan clips with it and it's the same mounting as with the IFX-14 ;)
The HR-01 is good with slow fans and the HR-01 Plus is even better. I dont know much about the Ultra-90, because is never tested it, but I think the HR-01 is better
