Oh man..another XP faster than me... :mad: SAE, I'll beat you :stick:Quote:
Originally posted by SAE
Here's my effort for the Barton party ;)
Nice clocks my friend ;) Maybe you should putt it on Ministry.
Done :thumbsup:Quote:
Already have one at 47.13 :D
Gonna get better :) LOL Fewture's a$$ 's gonna be kicked ;)
Here's my new one :)
argh!
:p:
Insane time my man. Very nice!! I have a 3GHz Mobile now and 270Mhz BH-5.. Only need a mobo so you better start cranking now ;)
:toast:
I am not sure… this might be fastest result with Barton chip…??
http://www.vr-zone.com/ocdb/amd_scre...s/181iii.pjpeg
http://www.vr-zone.com/ocdb/amd_screenshots/181ii.pjpeg
Mobil Barton 2400+ AQYHA0413VPKM
2X256MB TwinMos TMD7608F8E50B
Abit nf2-s rev 2 Bios D10
Vcore:2.15 v
VDDR:3.1V
VDD :2.2V
Zelman 400W
Cooling:LN2
Crazy stuff umekami! :toast:
Just Crazy :D
That CPU speed with a bit higher FSB would be a total killer!
Vcore:2.15 v
VDDR:3.1V
VDD :2.2V
Zelman 400W
Cooling:LN2
that speed.......:eek: :eek: :eek: :eek: :slobber:
Not highest Mhz, but fastest PiFast I think. Very xtreme result my man :toast:Quote:
Vcore:2.15 v
VDDR:3.1V
VDD :2.2V
Zelman 400W
Cooling:LN2
Hey Fewture :D ...But it's no 24/7 rig there ;) Ours are :cool:Quote:
@umekami10
Sick clocks there :thumbsup: but with LN2 it's not that problem, isn't it ;) ?
Thanks everyone:)
Macci
There is no way to achieve higher FSB in this ABIT board…Multiplier 13.5 and 14 do not work…over 220 FSB… I can of course run 250MHz low multiplier(under 10)…but no use...
@SAEQuote:
.....But it's no 24/7 rig there ....
@umekami10
....... but with LN2 it's not that problem, isn't it ;) ?
I got that chip a few weeks ago and tried to test it with every possible “cooling means” I got.....
I found the following results:
2550-2600 MHz Air cool
2650-2700 MHz H20
3100-3150 MHz (modified prometiea)
3200-3300 MHZ Dry Ice
3400-3500 MHz LN2
By the way You are absolutely right about 24/7 :)
BUT:
First was testing then arose knowledge…
The best way to find out if it is problematical or not to use LN2 is to test it. I recommend you to try LN2 and tell us later what you finding…. :) :toast:
If you like the results of Dry Ice and Prometiea look at this page...
http://forum.sweclockers.com/showthr...ight=umekami10
Nice results anyway as I already said :D
What are your 24/7 settings and cooling (prom I assume?!)?
It's a shame this board cannot supply you with higher fsb... :(
(did you already try tictacs latest bioses, L12 mod etc?)
Mod the hell out of the board! Do the 3 in 1 mod. 240 is easily doable :)Quote:
Thanks everyone:)
Macci
@SAE
2650-2700 MHz H20
3400-3500 MHz LN2
BUT:
Here is my quick test with slow CG-stepping
http://koti.mbnet.fi/rude1/Kuvat/A64/45.08.PNG
rude
seems a bit low score for the overall speed! Slow memory timings?
Memory is running at 2-2-2-5-11-16, if I put it like 2-2-2-5-7-16, it wont run above 240 mhz :mad:Quote:
This is slow, I think that is just the new stepping, it goes higher, but performance is poor. LDT is 2X and tREF is 2x3120, I dont know about tREF, which one is fastest of those many options:confused:
I just tested PiFast a little for the first time, I have only tested with SuperPI before. I like it. :)
Tested with "low" CPU speed, I'll see if I can get any higher later. Will see if I can get sub-50s. :)
http://home.no.net/endreke/bilder/PC/PiFast_51.31.JPG
Setup in sig, that's air cooled 2400 35W, NF7 and TwinMOS BH-5@2-2-2-11.
I just looked at the ranking list... is this really the fastest air cooled Barton? Extreme air people, wake up! :D
Edit: From what I can see there is no one with none chilled water that's faster either. Hm... I'm not impressed by the water and air OC'ers. :)
Lookin'good m8. Crank it up and show us some 49ers :cool:Quote:
I'll see what I can do, although I only have an MCX462-V to cool with, and it's getting hot here now.Quote:
Which program do you guys get the higher CPU speed in, SuperPI or Pifast? I could do SupePI 1M up to 2815 or so last night... hope to get something like that later today in Pifast.
Saw at Ministry that HaLDoL has 50.43 with aircooled M2500. I'll try to beat that first. :)
:p: with 3-2-2-8
OCz EB stuff?
Improved a little... not 49 though, I need higher FSB. :(
http://home.no.net/endreke/bilder/PC/PiFast_50.50.JPG
yea but i dont have no means good unbuffering bandwidth.Quote:
Originally posted by zyx
:p: with 3-2-2-8
Just 2 more Mhz on FSB should do it.. Maybe talk nice to your rig? :p:Quote:
LOL, well, I guess I'll try everything. :DQuote:
OMG :slobber: on air 2.8Ghz, I gotta have me one of those :stick:
http://home.planet.nl/~dikke332/5158.jpg
I think I can reach 250 on the memory which is holding me back, but I'll need more than 3.5v on it... Maybe I will try 3.6 :D
Just have to turn up the VR on the 3.3 sense line I guess ;)
