Thanx for answering.
ET6 doesn't even get to a control panel. The prog asks for permission, I get the little greenish wheel turning then.............nowt
Under processes task manager shows "Gui.exe *32"
Well it looks like the process is running, not sure about the ask permission thing I have user account control off & I am the admin of the PC so nothing gets in the way. I have the steering wheel in the task/toolbar whatever you call it on the bottom right hand side of the screen. I also have show all icons enabled in task bar properties so I see all things running. All I do is double click the steering wheel & it opens.
well i finally grab some patience and wait for 25 loop linx :D
#L045B021
http://img171.imageshack.us/img171/2...7linxx25ok.png
http://img52.imageshack.us/img52/685...7linxx25ok.jpg
http://img716.imageshack.us/img716/2...7linxx25ok.png
http://img269.imageshack.us/img269/2...7linxx25ok.png
Uploaded with ImageShack.us
cheers to all :up:
Sergio
you're going to kill that chip with stability testing LOL, i wouldnt do that and i wouldnt run that much vcore on 24/7 imo
andressergio you are running that chip 24/7 at those speeds?
Imo, stress tests are fine for the sake of it...testing. Put it that stress for 24/7 and it will asking for trouble which is degradation...especially on air.
It just my 2 cents:D
A little Question about P67A UD3P
I believe it's not much different BIOS setting between UD7 & UD3P. it's kind of weird I hv set
up to 4.8 Ghz as my sig with 1.392 VCore stable with prime95 1 Hr. but once I restart some time it's
crazy reboot loop with no reason until I hv to unplug PSU will stop the problem. It's happen randomly
I can'r guess what cause of these. Anyone have a suggestion?
BTW: I use F6a beta BIOS to unlock CPU PLL overvolt.
The easiest way is to flash the backup BIOS to match the main BIOS by pressing alt-f12 quickly at POST, before you get the disk drives screen ...
yes i found the issue in my board the UD7, on the timmings part search for IO latency its on AUTO put 2 instead so when you reboot your PC will not boot loop just sometimes wich is a known issue when you lett it of for a time and then turn on will loop 2 times but will load your settings perfect :up:
this is just my experience
cheers and good luck
Sergio
Anyone know if GB are doing a GOOC UK event this year?
I'd like to go to something this year & a UK event would be great rather than going to CeBit.
Sorry for OT :D
I run my 5Ghz OC 24/7 at 1.38v LLC 2. Been folding at full load all day since I got it and no degradation.
newhit - ET6 works fine for me with W7 x64, never had an issue. It didnt work in XP at first but that was only because I didnt have that intel engine management thing installed. You running it as administrator?
at certain times llc2 could be welcomed cuase of the deep droop this board does . . at 4.8 im at 1.460 bios 1.452 idle 1.418 load lol crazy . But to stay withing 1.500 envelope at higher clock like 5.0 i got hit llc2 so it does opposite with idle voltage and load . . starts low and hit load a bit higher , can it do damage yes , remember if you set in bios 1.45 , on load youll hit 1.52 . . . RED ZONE for none benchers
LLC 2 gives big time jump in vcore. At 1.38v set in BIOS and LLC 2 I get 1.425v load, 1.405v idle. You can also use dynamic vid to fine tune.
eldonko you have like the perfect chip lol.
