My 5890!Quote:
I agree with your estimations of a 5870OC / 5890 however where the hell did you pull this 920-935@1.15V number from :confused: I've used 4 different 5870s ( one of which is my own ) and not a single one claims such a feat ( I doubt they'd do 850 at 1.15 for that matter ) AMD have even upped the stock voltage from 1.168-1.172 on the reference bios to improve stability.
If anything they needed 1.2 (mine needs 1.237) best case to get 925. Now this isn't to say with improvements it couldn't be done but this just doesn't seem indictive of reference launch cards ( the cards I've used were all revision 1 with initial bios, all tested in 2009 ) Sure a 4 card sample isn't huge however they were all from different vendors and all consistent in how much voltage they seemed to play nice with (or not). Anyways just a pety thing to kick dust up at, just found this statement to be a tad up in the air is all.
I'd love to see a 5890 with at least 950/1300 clocks coupled with 2GB of memory. That should offer a 5-15% performance bump over a 5870. Going by the leaks so far, this would be more than enough to challenge the 480s. Given those supposive 512sp leaks were at 2560x1600, in some cases with 8x AA, im shocked the 5870 doesnt fare worse with its vram handicap. Should bode well for a future ATI refresh.
:D:D:D
http://www.abload.de/thumb/graka2252u.png
:D:D:D
You must even choose the good ones man!
