Originally posted by =[PULSAR]=
Yep 1.1 with a working lock, but why lock the AGP/PCI when its helps 3D performance. Well in bios you can only set it to 2.8v but once you get a OS installed get the first version of uGuru and you can raise it to 3.2v, so the first time you boot just set the vdimm to 3.2v and reboot to bios and you will have a couple wierd characters where vdimm should be but under voltage monitoring it shows 3.2v. Also, VTT does not go any higher than 1.4v so you dont have to worry about burning the mem controller on your cpu.
