my case, not to be compared to the others... and keep in mind it is a case that costs around 20-25€, pure codegen:D but it serves it's purpose: well cooling
logo on the side panel:
http://www.imagesforme.com/thumbs/36...lova_blizu.jpg
side panel with fans installed:
http://www.imagesforme.com/thumbs/7601DSC00767.JPG
look from inside on top where i mounted the water radiator:
http://www.imagesforme.com/thumbs/4114DSC00813.JPG
from outside:
http://www.imagesforme.com/thumbs/6437DSC00812.JPG
one papst was bought in the store, while the other two are from broken IBM server. here's the shot of it's label:
http://www.imagesforme.com/thumbs/154DSC00809.JPG
the front:
http://img174.imageshack.us/img174/5...ilednb7.th.jpg
all put together, no side panel:
http://www.imagesforme.com/thumbs/7264poslije (1).JPG
yes, the tubing should be shorter, but i'm buying a new case soon, so i could use longer ones.
