Originally Posted by mike.elmes
yeah sound very good... Try better ! :toast:
exactly what i was calculating i needed for 30 if my ram could scale up to highQuote:
Originally Posted by arbiter
Superior :)
what cooling are you useing on that proc?Quote:
Water Chiller(-2c alcohol)
no cheating:
http://www.try-this.dk/30sekPrescott,1.jpg
Watercooled with 9°C chilled Air! :D
http://people.freenet.de/funkflix/25min32m.jpg
Errr with my S754 Newcastle @ 2920Mhz 265 2-2-2-5 1:1 I get about 38mins at 32M ?? Wtf I'm doing wrong here ??
Windows 2000?! ;)Quote:
Originally Posted by sai
Yep, what else should I take ?
WinXP/Win2k3Server/WinXP64Bit. ;)
WinXP = Win2k + useless colorful :banana::banana::banana::banana:
WinXP64 = beta no good gfx performance
I will never get XP for daily use! I'm still with Win2k! ;)
So this is not really a solution to my problem, I don't think XP will give such a boost
p.s.: When I use a mem divider my times are more than bad
Sure it is! Whatch at ur CPU-"Nutzung" in Taskmanager while u bench SPi
bigger then 4M with Win2k, an then take a look with XP or something!
WTF ? Why it's going down and up like mad ?
35 sec on 3200, k8n (939) and Ocz vx at 10 * 240 :D
anyone want boost super pi on windows 2000? :D
LargeSystemCache=0
http://learn.chez.tiscali.fr/divers/...2M-10loops.png
LargeSystemCache=1
http://learn.chez.tiscali.fr/divers/...ks-10loops.png
beware if you use largesystemcache & the catalyst:
http://www.ati.com/support/infobase/4217.html
@Learn.... where did you get that de-compiled SuperPi from ????
Originally Posted by bachus_anonym
me, it's for my personal use.
it's the original super pi EN (no patch)
my new 32m
24.32s with 3400+ newcastle 1.84 vcore 1x512 bh6 corsair with 3.3vdimm
dfi nf3 win 2003 64bit 2 stage phase change by "ice" of greece ***thelab.gr***
:toast:
edit with 183 divider 11.5 multi memory at 251mhz ;)
It seems the 64 bit O/S helps considerably!! what was your score on 32 bit??
Nice score by the way. :)
Here's mine...
Is that LargeSystemCache tweak considered a cheat?
Does it make much diff?? I used that tweak but didn't do a before and after.
