in most shops they say "verfügbar ab 13.04.2006"
Sure, yeah :nono: ;)Quote:
Originally Posted by zbogorgon
what voltage are you using ?Quote:
Originally Posted by wwwww
ibby
@ Hi cookie
where did you buy the super talent memory from ?
ibby
from hereQuote:
Originally Posted by ibby
http://www.ewiz.com/detail.php?name=T800UX2GC4
do you have a step 4 or step 8 cpu ? (cpuz)Quote:
(im preparing for ln2)
lolQuote:
Originally Posted by Waus-mod
expect result.
Hi
Which the best overclockable and cheap ddr2? (~200$)
thx
are we going to use the hole 5 liters today :DQuote:
Originally Posted by hicookie
*edited to make sense :D
Max everything: 1.5V CPU, 1.675V chipset, 2.15V memQuote:
and it's Stepping 4
hmm I need a new CPUz - says it's an Intel P6 Processor...
Ihs glued on. Liquid electrical tape on the board. So 2 things have to dry before i shoot.
Flash to new bios ?Quote:
I'm not so sure that's true but we'll see I guess...Quote:
Originally Posted by Willis
is FSB limitation (most guys are stuck around 230-236 or lower) due to having the Stepping 4 ES, or the motherboard? Has anyone tried a retail chip, and if so, can you get past this FSB wall that many are hitting?Quote:
Could be the CPU or the mobo, but I've seen Stepping 4's higher than this. Can't seem to up the multi either :( - I'd expect that much from an ES...Quote:
Originally Posted by Ramen
Yeah multipliers are only available downwards :\
someone suggested upping the pci-e frequency, like many had to do with the p4gd1/p4gpl-x boards to get to higher FSBs, but it looks like that didnt have much success with the i975x-ydg
Having that fsb wall really sucks, especially if you do not have a T2600 to play around with. My poor T2400 with 11x multi :(
dont worryQuote:
cheer up
People with big ears are looking for fixes.
Definately has alot more grunt in her - works fine @ 1.3V
ths mobo can't set to cl3 at 800, my p5wd2ep did.
i think ths board are not good at timing.
coolaler's 3.1G dual32m
http://www.coolaler.net/YONAHT2600/Dualspi.gif
my 3G dual 32m
[IMG]http://i19.photobucket.com/albums/b1...ualpi32m-7.gif[/IMG]
os the north bridge getting warm >
grrr this is annoying
224FSB = 100% stable in everything
225FSB = instance freeze
nb a little warm - nowhere near p5wd2 warm
cooling?Quote:
tuniq tower 120.:)Quote:
YES !!!Quote:
11.4.2006 um 14:31 Uhr Ihre Ware wurde kommissioniert.
11.4.2006 um 19:12 Uhr Die Ware wurde an Sie versendet. (1 Paket(e))
Easypanic, your stuff is shipped too :)
hmmm made it to loop 3 in pi 1M @ 225FSB by setting mem to 4-3-3-4 (cpuz says 5-3-3-0)
