I bet you were running Small FFT's. That doesn't test RAM at all, so i'd agree RAM is most definetely the issue. What do you have? If it's TCCD it shouldn't be having an issue by now, unless you're running 2-2-2-6 in which case loosen to 2.5-3-3-6.Quote:
Originally Posted by kimandsally
If anything else, try raising the vdimm one notch, then loosen timings, then finally if all else fails, just use a divider.
