I will post some bandwidth shots if you like to show its running 263mhz.Quote:
Originally Posted by Lestat
I am a bit stunned myself. :confused:
This is good no?
Check here
This is good no?
Check here
No. Its insanely great! 2.9Ghz@1.4v and 265HTT tight timings 1:1 @3.24v - SuperPi 32M stable! :slobber:Quote:
Originally Posted by musk
THATS BEYOND INSANE MAN THATS IMPOSSIBLE.
oops caps sorry
3ghz at 1.4v no way impossible unless your running vapochill and even then i doubt 1.4v
3.24v @ 265mhz again not possible
and thats a pretty iffy Pi score for 2.9ghz and 2-2-2-6 263 (or is that about right ?)
frankly man your voltages give you away... the only way that ram could run that high is if its ddr550 chips and Mushkin put them into the redline 4000.
i mean seriously the ram is 3.4v @ 250mhz so you think he can run 263 at LESS then 3.4v ?
i dont mean to be the party pooper but come on now im not fooled.
how many 3ghz @ 1.4v chips have we ever seen ?
look at your 12v+ Rail what the heck is it running 12.8v for ?
that has to be making everything run overvolted... or something.
i just dont believe thats real.
if it is i humbly apologise.
gundamit -
your on a phase change with a 3000 winnie and you still had to go to 1.64v to hit 3ghz
i'd like to at least know your cooling system...
I would like to see a CPU-Z validation link since the odds of getting two miraculous performers between the CPU and memory are incalculable. Turn in another miracle on your video card performance and I think you qualify for XS sainthood. :p:
Originally Posted by gundamit
hehehe well said !!
too bad cpu validation dont show cpu voltages so a validation dont mean anything really.
3ghz on a 3000 is possible, rare but possible. and definatley not on air.
air with 1.4v hell yes. god what a dream that would be.
im sorry i also missed the chip markings whats the date code and all those goodies.
your also playing online poker.... wow dude if your that lucky at online poker can i come be your best friend ?
ya my 3200 venice is def not very good....
even on phase it maxes out at 3120.......week 0518 is just not that good....
Hey! dont threat the 0518 CPU's!!! my 3000+ 0518 CPAW is doing a great job!
ON AIR WITH 1.625VOLT HE DID 2933MHZ! this week it will be with WC!
i'll post my results then ;)
This cpuz validatedQuote:
A little 1:1 to displace divider issues.
I don't know whats up with the 12v rail
http://img.photobucket.com/albums/v475/musk/1to1.jpg
lol hehehe "even on phase change its only 3120 lol like your disappointed.
sheesh even when supercooled a cpu can only go so far. lol
well musk if your truly running 3ghz @ 1.4v and 264mhz @ 3.24v you have the rarest cpu/ram combo i have ever seen.
just go behind your psu and turn down your 12v line a little those powerstreams are adjustable ya know.
wanna sell it ? lol im sure you dont need all that for online gambling lol.
My venice can do 3.02 Ghz on air but not nearly stable lol
I can run sp1mill at 3ghz but it needs high volts (1.58) and temps dont allow it to be safe. I think it's just my board reporting bad temps or something or bad IHS contact.
Cool. Now about that CPU speed ... how about a validation for 2.9ghz or higher. :)Quote:
0515APAWs are amazing CPUs. Mine did 2.70 Ghz stable on stock volts but hit a wall immediately after that... so they're amazing but weird CPUs ;P
my statement of "not on air" i guess was misstated.
yeah it could do it on air but not safely.
BUT since it is supposedly only 1.4v that would make temps just crazy low.
i still have my doubts about the ram and cpu both running so high with such low volts.
what the devil happens when you raise the voltages ?
seriously have you even raised the voltages yet ?
3500+ LBBLE 0517APOW - 2806 Mhz 1.47v XP90C prime stable
here you go. :D http://valid.x86-secret.com/show_oc?id=36658
hows thisQuote:
CPU-z ID = 36359
http://img.photobucket.com/albums/v4.../inprocess.jpg
I am in the midst of testing more voltage. The RAM definately needs mor volts to go above 265mhzQuote:
http://img.photobucket.com/albums/v475/musk/265at3.jpg
To get 270 32M stable I needed 3.57v
Will post more later. I am running prime now at 2900mhz/263mhz at 1.43vcore and 3.24vdimm - !/2 hour so far on Blend
just got a 0530 E6 Venice 3000+ today.
quick testing:
http://home.earthlink.net/~sgallai/images/a64e6.JPG
Also using a new motherboard - nf3 DFI
it SEEMS that its worse that my old venice 3200+ e3. but i have to see how it scales. seems that some cpus scale well some dont.
Originally Posted by kapster
Kapster that is the same with all cpu's you could have 2 with identicle steppings and dates and one could just smoke the other one.
you also need to be sure that you have a bios that supports the E6 cpu's . i DOUBT it would cause a chip to not clock as well but it is possible.
also dont forget that the dfi board still has issues. Why ? god only knows they had a kick ass 754 board and a kick ass 939 NF4 board so why they had to go and mess it up with a goofy NF3 board i dont know.
do you still have your old board to test the cpu in ?
Musk.
i gotta tell you man if your legit. (frankly cpu-z validations dont mean squat to me since there is no voltages shown in cpu-z, why i dont know i do believe they need to add that.) Then you my friend are one lucky S.O.B.!!
and crank that mushkin up more you can run 3.8v on that stuff but thats the max id ever EVERgo and you better have a couple of fans blowing on the ram. and some nice cool case temps.
even right now with your current voltage settings i hope you have atleast 2 fans blowing on the ram. otherwise your gunna kill it from the heat .
Are you this lucky with your online poker endeavours ? lol.
I dont think i need to say anymore about my doubts im sure you can look thru the thread and see your chip is a one of a kind of one of a very very small handful.
and frankly ive never seen mushkin redline run that high on such low voltages.
ya never know you may want to NOT touch it lol. just let sleeping dogs lie.
Lestat,
I got my neo2 on the workbench still. I took a couple hours setting this all up because I also had to set up my watercooling.
ive heard plently of reports about the board being buggy. Im pretty sure I got an e6 bios out of the box as on post it says 1 CPU.
At this moment im experiencing cold boot problems when using the top 2 slots for dual channel. I had no problems with the bottom slots but it seems the top 2 overclock better.
Lestat,
I am pretty lucky at online poker. I have 12 million play bucks. :D
I am being careful with the Redline because I can't get much air flow to them. I have a Lanboy case and its pretty full with WC gear. I have a stock A64 fan blowing accross them and they are cool to the touch for now. I am trying to rig something up to get more airflow so I can crank the voltage. I am also noticing that my chip runs very stable up to 40c but after that it gets a bit flakey. I might have to put a good fan on the rad.
I am going to play for a couple days before I post anything else. Please give me suggestions of what you would like to see run as far as tests go.
kapster, thats interesting. and i mean very interesting.
so you have a brand new NEO2 that has a E6 bios in it ? thats pretty wierd.
and more odd is the 2 top slots work better. mostly the bottom 2 closest to the cpu work better, but in general thats a rule fo thumb for every motherboard.
Musk right now dont touch a damn thing
run prime95 today and tonight.. let it run dont even touch it. this is gunna "break in" the cpu.
Technically from every electrical and technical standpoint a piece of silicon can NOT be broken in . It's not a wear and tear item . It either does its job or it don't but a large faction of the overclocking world will tell you to break in the cpu so i pass that along to anyone i talk to.
leave everything the way it it and run 24hrs of prime 95 not the regular prime but the torture test.
what you could od is either setup prime95 for cpu only or ram only and then after 24hours switch to the other or run the mixed mode.
personally id do 24hrs of both.
then go ahead and raise the voltages up to 1.45 or 1.5v and see what happens.
if you had to go alot higher on the vdimm with the ram just to run 270 thats normal. but also remember that 95% of redoline users must run 2.6v or higher to get to 270, infact id say a good percentage of redline users cant even reach 270mhz.
so if you can reach 270 at less then 3.6v be happy!
lastly... you can not touch a thing.. .and just let it run for a week doing your normal everyday thing and then turn it up a little./
Me ? i run them for about a week and then turn them up.
but i also did that with this 3200 of mine and at first i though it was gunna be a good.
little by little i was able to get higher without rasing voltages.
but now im sliding back downhill.
i can no longer go over 2.5gh without the system crashing. and thats even at 1.7v. she just wont do it. so the chip is dieing.
and frankly im gunna crush it lol and then go get a 3000+ :D lol.
maybe just my addition to the 24h prime stable thread.
http://www.xtremesystems.org/forums/...59#post1028859
