The 478 thing is confusing me. It makes me want to buy on one and just pop it in my max3
Yeah, come on ASUS!!!
P4C800 needs better BIOS, too.
C
Ok i see that Dothan overclock nice. But how is it's life performance in gaming. I heard that FPS is not stable could fluctuate 40 -50 fps. Also is it stable and bug free?
Does anyone actualy gamed with this cpu? Please share your experience with games you play on CT-479 :D
well i played the demo of "area 51" on it with a 6800u the monitor limited my res since its a 15" 1024x786. the game was really smooth, i havent had the chance to use the 6600gt yet in the rig. the 6800u is on loan to me from a friend. its really quick with that game... havent had the chance to play anyothers just set waiting for new case and psu.Quote:
Originally Posted by railer
Haven't compaired performance vs my A64 yet. Mainly because Gigabyte hasn't told me anything about my RMA yet. But I've played several games and everythings smooth so far.
I have noticed the lack of hyperthreading at times. One area that really lags is opening those damned pdfs and spawning Reader. :upset:Quote:
Originally Posted by Lithan
Finally got 3dmark to work.
35,574 with 12 pipes. 40 pts from the record. :cussing:
Yes i agree the 2.8 with HT is a smoother but everything i do day to day to either quicker or the same.
I use a program called videoredo to edit add breaks from mpeg2 recording of my sagetv box and it's no differant to the p4. also dvdlab (dvd auth software) runs the same.
I tested doom 3 1280-1024 high q time demo1 90f/s, mid q 100f/s halo runs at about 100fsb live for speed never drops below 70fsb no matter how many cars and need for speed underground 2 with everything on is minimum 60f/s.
Just waiting for some geil ultra platinum pc4000 so i can run memory at 1:1 as my crappy twinmos sp 3500 died on me and i dont like using the ddr booster. Running at cl2.5 will lower performance a little but higher bus speed will make up for it.
I still cant explain why i cant run at 11x233 any more same cooling , i have vid 4 and 2 for 1.64 vcore but my board shows 1.568-1.6v and get lockups / resets at 232. I could run at 235 when i first used this m730 and had vid 4,1 and 0 for 1.62v.
The only thing differant is i am using a 6800gt instead of a 6600gt could is be a power issue. I am going to run 2 psu's one for the mobo-ct-479 and one for everything else see what that does.
Originally Posted by uclajd
What psu you got?
Btw, what 3D 01 score you get @ 2750mhz?
My psu is a antec truepower 430. it is happy with a p4 2.8c at 3.7 4x120mm fans on 2x 120.2 rads ,mcp650 5x hdd and dvd-rw so it should be ok with just a mobo, dothan, 6800gt and 1 hdd.
I could do another run but at the moment i have fsb at 230 and ram at 186 -2-2-2-5 so it's going to be lower than before anyway. I should get the new geil pc4000 tuesday so will give it another go then.
at 2.8 with 6800gt stock i scored 28k with 6800gt at 400/1100 almost 30k and 6800gt at 410/1150 just over 30k.
Originally Posted by Bennah
anyone with a dothan, care to do a quickie 13x184 1:1 spi1m run?
i'd like to compare it with a cel M: http://www.xtremesystems.org/forums/...d.php?p=899572
Using new 1022 beta bios. On air with default hsf. 100% stable
http://valid.x86-secret.com/show_oc?id=21913
did you use any voltage increment?
super pi 1m on a untweaked os
will be goin for 24secs over the weekend soon as i vdimm mod my mobo and use 1:1 on the ram
cpu = dothan 730 2mb 533fsb
mobo = asus p4p800-e vdroop modded
ram = 4x512mb twinmoss bh5 @ 2-2-2-5 2.85v
air cooled - Zalman CNPS7000B-CU
http://img260.echo.cx/img260/1065/wo...oo25sec6fv.jpg
waitin on my agp x850xt pe - then gonna be goin for 38k 3dmark01 all air cooled
shigs
what is vdroop?
mod on the board to stop the voltage going all over the place.Quote:
Originally Posted by bcn
Its called vdroop because it can be fixed with a minor mod that can be compared to how some ppl use Viagra :horse:Quote:
Can somebody help me with my P4gd1 ? I can't get over 150 fsb > 150 pcie
Everytime when i set with clockgen 151 fsb clockgeb or cpufsb freeze .
When i set up 200x10 freeze to
Well if your CPU is a FSB400, there you might have the explanation; they don't clock as high as their 533 counterparts :(
150x16 is 2400MHz BTW, which is okay without Vmods and the like, or is it 151x10 you are trying?
Its now ok. I set up pciex from 100 to 110 and now 2520mhz
730 arrived thismorning, hopefully it'll turn out better than the 715...
Running Pi (passed all tests so far, on 8mb now) 213*12 on 1.4v which doesnt seem too bad. Much better than the 1.5v it took the 715 to get to 2.4ghz.
Seem to have freezes at anything over ~ 213 though, have a feeling its the POS memory, need to get the TCCD in it later and test more.
Not bad for starters though.... :D
What about changing the divider to 3:2 to see if your memory is holding you back? :)
Done that already (all latest BIOS):Quote:
Originally Posted by cirthix
Aopen AX4SPE MAX = No POST
Abit IC7 = No POST
Abit IC7 MAX 3 = No POST
Epox 4PCA3+ = No POST
I tried forcing my 400FSB to 533 by doing BSEL 0 to VSS to force BSEL 0 L(Low), I think that was correct, but it's been a long time since I've bothered with wiretricking FSBs LOL. (pic)
http://www.meltdown.fsnet.co.uk/pics/Intel/vidpins2.jpg
Anyway it made no difference whatsoever. But maybe it should have been BSEL 1 to BSEL 0 to force Low? I though VSS was the same result.
(Whoops, posted this in the wrong thread LOL, nevermind eh?)
Cheers,
MM
hello guys.. i just gut:
1.asus p4c800e-deluxe (droop mod)
2.asus ct479
3.dothan 740
4.vapochil xe
5.crosair xms 512x2 pc4400
and i have aLOT of problem!!
1. i do the u-wire 10 tims to get 1.660v and it didnt work. in the bios i see only 1.584! which vid i need to conect and with what?
2. my dothan temp are -25c' and i cant boot at 200/201 fsb only 195 no more!! even with clockgen if i goo one mhz above 2590mhz my computer is stop moving!! :confused: why is that??
3. i see here many guys that post at 200/201 fsb with the same thing (740+p4c800e-delouxe) what i need to do to pass this problem?
thanks :clap:
1. It won't be reported correctly in CPU-Z or the BIOS; as far as I know it won't be reported at all. You'll just have to ground it correctly and it'll be running at 1.660v.Quote:
Originally Posted by ye_3333
I think that there is a bios update that allows you to POST at a 6x multiplier, which will let you post at 201 MHz FSB much easier.
