Does anything need to be plugged into the SATAs for a post? I'd assume no but figured I'd check. Not having any luck so far.
haven't tried that... make sure you clear the cmos and have everything hooked up right. sometimes this board can be a little picky
Wow okay, it didn't boot till I plugged in a HD. Won't boot off an old PCI I had or a 8800GT, working off a x1300 ATI card though. Picky board for sure. The OBEY logo is hilarious though.
lol i know, joey scared me!! he made me feel dirty
Dang my arima put up 68000 points yesterday!!
I have not read this whole thread so if this was posted elsewhere, sorry.
TYAN S4985G3NR Thunder n4250QE Quad 1207(F) NVIDIA nForce4 Professional 2200 + 2050 SSI MEB footprint Four AMD Opteron (Rev. F) 8000 series (dual/quad-core) processors Server Motherboard Really nice board for $199, closeout look s like as Tyan lists it as EOL. I would like one but can't do it now.
yeah you might as well get one of our google arima boards for about $100 less.
uh oh.. now i want one.
Newegg does not update details of motherboards and many motherboard manufactures do not update their web sites and the only way to know what a board supports is to check the BIOs updates and even then you sometimes have to download the BIOS and hope for a text file or decompile the BIOS. In my experience Gigabyte is the best at getting it done.
I found out after buying that that link is for the S4985-E version board here is the link for the S4985 which is $199 on Newegg.
From Newegg reviews. I do not own this board so I can only go by what I am reading others claim.
doctor_b
8/25/2010 8:01:57 AM
Pros: As one reviewer previously noted, the BIOS program for S4985, S4985-SI and S4985-E are one and the same. So I implore all of you, whether you just got this board or have been its proud owner for many months, please update its BIOS to v3.02. Despite what the Tyan website may say that v3.00 and above are only for Istanbuls and Shanghais, this is NOT true! I have Opteron 8354s (Barcelona cores) and BIOS v3.02 can initiate the cores just fine! And of course, this BIOS update WILL allow this board to initiate Opteron Istanbuls and Shanghais (AMD AGESA upgrade in BIOS).
Laz
9/11/2010 10:28:07 AM
Also, when I upgraded to a Shanghai 8493 3.1 GHz, Win 7 only read that it was clocking at ~2.5 GHz. But once upgraded to 2.07 (will probably upgrade to 3.02) and enabling certain settings in the BIOS, worked and got Win 7 to read 3.1 GHz.
Maybe Newegg is now shipping the newer version?
Hello,
On my motherboard i have 4xopty 8218 and i use an thermaltake purepower expess 650w ( Full 12v psu ^^ ).
But... i have a new problem ...I cant acces to the bios, when the system start and that i put DEL the system are blocked on : " Entering Setup" .... After ten minute i shut down....
Have you an idea ?
And where can i DL the last bios ?
THX !
What motherboard?
on the arima f3000 with the logo obey ;)
My only suggestion would be to go down to the bare minimum hardware to get it to boot i.e. one CPU one stick of ram?
I m testing but.... "Entering setup..." : Perapse the problem is my Vga card, it s a very old pci ati...
not likely but possible. i dont know what else to say. did you say the board boots to desktop or not?
No, i have not boot to desckop. i need to change priority boot ....In bios.
Thx. I test an other vga card in few day
why do you have to change boot priority?
Hardware testing ;)
You mean crunching?!
What better way than crunching to test a cruncher?
I can't think of anything. Glad you got her up and running! What were the final specs you went with?
