Well in searching about 6 forums, so far I have found subjective reports of the following degraded/dead 45nm chips...many link back to here:D
Most deaths occurred from running above 1.5v and/or benching at ?1.6+, and one died from running fsb 600 for 6 hours 1.4v max.
Degradation (needing more volts for booting or stability at same mhz), most occurred at volts 1.45 and higher, many noticed after stress testing orthos/prime/occt at 1.45 and higher. One report of degradation occurred ? after primed fsb 545 10 hrs and had 511x9 with vcore 1.45 for unknown amount of time. One report on greek forum occurred after several days of 1.41 vcore, unkown if person went higher for benching earlier, unknown stress testing.
I think I am going to keep stress testing and 24/7 at/below VID limit of 1.3625 for now, or certainly no higher than 1.4 for 24/7. Also would not be priming real high fsb, though i would not do that anyways, since I only prime what I would run 24/7.
If anyone finds any that degraded at 1.4 and less, please post, especially if have specifics surrounding degradation.
http://www.csd.dficlub.org/forum/showthread.php?t=5556
E8400 primed 17 hrs at 8.5x500 at vcore 1.35
511x9 vcore 1.45 unkown time
primed fsb 545 x 10 hours unknown mhz, voltage.
then 8.5x500 at vcore 1.35 was then only 1 hour prime stable
http://www.xtremesystems.org/forums/...173999&page=45
E8400 needed additional +.075V to be stable at 4ghz (needs 1.45v now)
Known – benching at 4500mhz ? ? how high volts+ ?length of time.
? additional
http://www.xtremesystems.org/forums/...21#post2759421
post 1165
E8400 died
Known - benching 1.65v on air, running at 4300 on 1.5V.
http://www.xtremesystems.org/forums/...d.php?t=176287
Just says using 1.45 bios, 1.41cpuz ? load for 1 week, then became unstable
http://www.thelab.gr/showthread.php?...0&pagenumber=5
post 82 and scanning through other posts
greek forum, 6 or 7 people most/all running orthos at 1.5-1.55 volts on water, and ? all degraded after orthos runs or benching? And ? one at 1.41v seeing degradation ? orthos run
http://www.xtremesystems.org/forums/...postcount=3427
running it at 600 fsb for 6 hrs, no higher than 1.4V
Several Qx9650 and some E8400 benching at high volts 1.6+ with dead cpus, I did not bother linking to, I think everyone understands the risks now at high volts.
