I've got a little problem, a few days ago i started testing each tick of my 6 GB Crucial Values with D9GKX. I want to get the best 4 and stick the together, the other 2 GBs will end in my htpc. In Bios i set 2,19v vdimm everything else ram related on auto. After first stick hits 600 mhz memtest ok but 605 was a no go i got a bad feeling that something is holding me back. Nearly the same with the second stick, 600 mhz tested so far. For some reason i had to reset the bios and i don't knwo exactly what settings i made for vnb and vtt, problem is that the second won't even do 580 mhz again, 570 is memtest stable again, but i wasn't able to get my 600 back :(
OK 570 would be ok for value sticks i thought an moved on to test third stick.
again 580 was possible, nearly the same as the second one so what's going on, seems that the board is limiting me, isn't it ?
So what i need exactly would be some settings where i can start and how i can work on, since i don't have enough time to find out by myself.
NB is watercooled so temps should be ok, so what voltage would be ok for 24/7 ? Maybe i should try some of your Ballistix settings since they've the same ICs on them ?
