btw: i took one of your shots as my background ;)
I think in two weeks i will be after "refreshing" of my LC ;)
damn that awesome:shocked::shocked::shocked::shocked:
already have it as a wallpaper now :D
:up:
Malik Very nice shot, very coool
Very nice shots Malik! 'Cold as ice' :D
Thank you :)
Awesome shot sir! I love EK block too!
Hi Malik. Nice work mate. I wanted to know what size tubings you using and also the commpression fittings? i was thinking to buy the 1/2" tubings and the 1/2" feser commpression fittings but is see alot people saying they wont fit some blocks which have the holes very near to each other. can you give me some advise please..
http://www.mazpo.com/ebay/images/P6T-920-2.jpg
http://www.mazpo.com/ebay/images/P6T-920-3.JPG
The main parts are as follows:
Intel Core I7 920 @2.67Ghz
Asus P6T Deluxe Motherboard
OCZ 6GB DDR3 Reaper Ram
Asus HD4870x2GB Graphic card
2 x 500GB Western Digital RE3 HDD on Raid 0 (C
1TB Seagate Barracude HDD (D
Kingwin March 100W PSU
Creative Sound Blaster X-Fi Titanium Sound Card
And the case is Lian Li PC-75.
I used:
Bitspower fittings 13/16 size
Tygon Tubes: 11.2/15.9 size
UPDATE:
Ok, all stuff arrived. Now i need time to mount all new things:
Custom version of HF:
http://www.abload.de/img/dscf4312h1sp.jpg
http://www.abload.de/img/hf_smalll1ru.jpg
http://www.abload.de/img/dscf4302_smallabm9.jpg
http://www.abload.de/img/dscf4297lb0y.jpg
http://www.abload.de/img/dscf4296obfu.jpg
HD Wallpaper:
http://www.abload.de/thumb/wallpapern0w6.jpg
More photos soon... ;)
very nice shoots Malik ! :) need to see your rig in blue ! :)
nice pictures as usual malik
I really admire your fine work and eye for detail
for what graphic card is the cooling block? for the back and Ram or a new EK Cooler?
Yes, this is EK ram block for GTX 280.
I think blue is the best color ( photo of old version ):
http://www.abload.de/img/dscf2353f32j.jpg
Maybe on this weekend all work will be finish ... i must find some free time for that.
Some new photos:
http://www.abload.de/thumb/dscf4299sbmb.jpg http://www.abload.de/thumb/dscf4304mzhc.jpg http://www.abload.de/thumb/dscf4314nzr3.jpg http://www.abload.de/thumb/dscf4315ubec.jpg
incredible work malik, you've been a lot of time updating your rig:D:D
I remember 1 or 2 years back when you just begin here, and now...xD its amazing work mate;)
Ok guys i just finished ... but that not what i want :(
http://www.abload.de/img/1kq4n.jpg
After 10 hours ... i find some problems:
1. QPI block - have to big bottom and i must make new one.
2. RAM block for GTX 280 - fit very good with new EK Waterblocks NB/SB block...but this combo look very icky:
http://www.abload.de/img/12boe4.jpg
3. When i mount this RAM block and new nb/sb block - there is too little space.
Tomorrow i will think about new solution about this. Now im to tired for this.
I got a question , you migth find it stupid LOL
In the picture i see that the water or the coolant goes by the res to the pump then to all the blocks and finaly to the radiator, how does the water gets back to the reservatory ????
I see no tube getting back to the reservatory , sorry if its a stupid question..
Can you explain me the scheme of your watercooling system ? thanks:up:
Hum interesting , i should have done the question this way , how does the water goes out of the rad , i see only 1 tube so i guess it goes up and then down again by the same tube to the blocks and back to the reservoir.. really interesting ...
I just wanted to know the scheme of his watercooling , thanks.
The loop is:
Pump - FlowMeter plus Temp Sensor - Rad 1 with temp sensor - Rad 2 with temp sensor - mof 1 - mof 2 - CPU - Ram - NB/SB - GPU 1- GPU 2 - Res - Pump
I don't agree with Main. There is no difference in perfomance of loop - when i change sequence of block, rad etc.
In this set i have 240litr/h in 100% power of pump. So all works very fine, temps are very good and the most important - im very pleased ;)
