Has anyone been able to get folding to run with the i7 in HT mode? Dave said it crashed every time he turned on HT... :shrug:
Yes it is a lot harder, as one guy posted at the folding forums one time, you have to format, install the O/S, download folding, run it, delete it, delete que dat, files in work folder, wash repeat, format install O/S stand and bow in the direction of Stanford, a lot of swearing and re installs, then babysit the thing then bow in the general direction of stanford again and it might work...
:rofl: I think Dave's doesn't mind most of that, but the bowing to stanford :sofa:
Jezus I need to relax a lil, I already hear this hush from a hammer falling on my head :sonic:
I think I'm gonna hit my 2M mark before thanksgiving! :D
Update: Picked up another 2673wu. Times decreased and leveled off at around 10m21s per frame. Pretty much in line with the 5400ppd on the 1920 point wu's. Seems okay for only 2.9Ghz ram running at 420Mhz. By the way, can anyone tell me....how much does system ram speed or timings affect F@H? (with SMP client)
DrJay depends on the work unit ( or better on the core ). I think dbgromacs utilizes the most bandwidth but can't find the reference for it anymore, and like I said it's also not just the core itself but also the work unit itself. Think wu's with more atoms and especially wu's/core's with explicit solvent models need more cross thread communications ( ~ bandwidth :shrug: ).
Hmmmmmmmm so tempting.
But jeeez the mobo and ram is gonna cost me. Maybe there will be some holiday sales after the i7 initial early-adopter rush slows down...
Just a "heads up" http://foldingforum.org/viewtopic.php?f=52&t=7063
I ain't touchin' mine, they be workin' fine so I'm leaving them be, they are happy now and I don't want to get nobody grumpy :yepp:
I'll not use drivers without knowing what their origin is and they will have to come from either PG ( as recommodation or w/e ) or directly from nvidia as official cuda certified drivers. I will not run other drivers because who will tell me if my eue's will be caused by bd wu's or bad clocks and not bad drivers :horse:
Lulz +1, never download and install stuff that isn't from Nvidia.com
I see a few of the big boys on my radar now... Just giving them a heads up that the steam roller is coming through.
Help me guys, I been straying from the path and suddenly found myself in a group of folding haters :poke:
Keep me on a shorter chain, so I shall not stray to far again :lol2:
I will be kind when I roll through the neighborhood. I am hoping to actually ramp up production. I guess we will see if that happens.
Haha, i can't freakin' get the CPU console client to run again, i reinstalled a vLited version of vista :confused: I try doing the simple "Run" and entering the .exe with configonly, i've tried running the command prompt as admin, i've logged in as admin and couldn't get it to run, tried it in different folders urghhhh so i just stopped caring for a while and ran the GPU clients. Man, i tried following the Wiki guide but when i go to properties>run as administrator or whatever you're supposed to do the box is greyed out and i can't do it, even when logged in as admin.
Well i have got it to run, it just doesn't have my username and team, unless that's an issue with Fahmon :confused: It runs correctly on my rig but i have the cmd window open, i used to be able to run it as a service IDK what the hell is going on..........i'm getting a new 22'' monitor at least sheeesh..
you went through this in the beginning of sept too King and gave up..
movieman "I never smp'ed before" used ths little guide last month and got it going after about 20 minutes.
of course that was after he screwed with it for 2 days on his own and was frustrated, and pming everyone...
then he tried this simple quick and dirty walk thru, and it worked. just don't skip through it and not read everything...
this is one of the shortest little walk thru's around. (not all inclusive for Marvin's needs ;), but it gets the job done).
http://www.xtremesystems.org/forums/...d.php?t=199283
:sofa: I only ment to help ;)
if you follow step one there, installing affinity changer, you can make it easier on yourself and just run www.mtm78.nl/maxfah/publish.htm ;)
Will download, install clients in c:\maxfah\, and configure them. Just still haven't finished the tray control nor can I fully automate it as you still need to follow the guides to configure either deino or mpich :(
Ow.. and it doesn't drop in the replacement exe as well. I'm slacking sorry :(
What's more important, an installer, a statistics tracker for xs, an eue watcher? Idk :shrug: I try to do everything but I guess I should concentrate on one thing and get it finished already :down:
Thing is I asked PG for coorperation by changing mpich package from gkware installer to zip as is the case with deino already. That would cause me to not have to shell to an external program, I can code the configuration of mpich and deino exactly as in the guides it's not hard to shell command line utils on the background and send input to it, but I feel if I would would code something to automate the gkware setup I'm doing something they don't approve of.
Even thought about another solution, getting mpich from the official site for it and just drop in the client exe, that would eliminate the gkware setup needed to be downloaded and executed. But I don't want to break eula's and like I said I asked about this weeks ago but as off yet haven't gotten a definitive answer :(
Each time I hit a bump I shift attention to another project, and the former get's neglected. I have plans with the eue watcher to connect to a webservice so eue's from people who want to participate in collection them can be posted automaticly ( if needed, like with wu's which don't send results to the servers aka 5506 ). I been working on a signature generator for xs folding team, I fixed my sql server so I'm not dropping tables anymore ect. But no single thing is done because I will hit a bump and my problems seem to make me not want to acknowlegde hitting a bump by moving on to something diffrent :nuts:
