will have one of these boards for me in two weeks, that when they'll be available around here :D
Is it known if similar problems with nvidia chipsets exist also ?Quote:
Originally Posted by eva2000
no probs with Trueimage v9 and v10 with my Asus 680i Striker .. only seems to be for RD600 since it's so new that software developers probably don't even have access to RD600 yet.Quote:
Originally Posted by 775911
Acronis will want $39.95 for the 10.2 update that includes full support for the SB600. ;) I spoke with them yesterday until I was blue in the face about adding full support for the SB600 since new boards are shipping with it now and will continue throughout the spring (690G boards all have SB600).Quote:
With Acronis I had some problems
I was able to Clone my array to a single IDE,
But was unable to Clone from the single IDE to the Array or a single drive
Stick it on an sata/ide card and access it that way?
darn really!, Acronis techs gave me a latest beta to see if it works but haven't tried it yet... sounds like it might now heh.Quote:
Originally Posted by bingo13
What is everyone using for temps ?
Core Temp (0.04)
or Smart Gaurdian?
Smart G, is reading about 10c higher on the core.
coretemp is only real accurate app. but use SG for showing voltages :)
Is the shipping bios the current one?
Thanks.
Corsair Nautilus500 w/c kit :)Quote:
Originally Posted by GNU
Not a great performer but I love it coz its easier and faster to install than stock HSF.
That is pure BS...not to mention Acronis 10 is not be as stable of a product from their forums as version 8..seems to have gone downhill from thereQuote:
I just ordered the RD600 and have ordered these WC parts:
D-Tek fuzion WB 1/2"
MCR 220 Radiator 1/2"
2xLaing DDC Plus 1/2"
Masterkleer 7/16" tubing
I need help picking the NB and GPU WB.
The DD Maze4 and the EK-NF4 Rev. 1.1 (will this even work) seems pretty decent for NB WB.
The AquaExtreme MP-1 GPU looks good for the GPU WB.
What do you guys think?
thanks.
cjoe
This might help you with waterblock selection for the NB...Quote:
Originally Posted by cjoe
http://i4memory.com/showthread.php?t=3488
I would personally choose a Swiftech MCW-30 for the NB and an MCW-60 for your GPU.
Check with the guys in the liquid cooling forum for more advice.
Thanks. That was a lot of help.Quote:
Originally Posted by virtualrain
Petras has pics of both the MCS-30 and the 975 Maze4.
The pics of the MCW-30 show a retention bracket that hooks to the four NB MB loops.
The Maze4 has a 975 version of the NB WB customized for the Badax which also has hooks.
Has anyone tried either of these WB for the NB?
Thanks.
cjoe
make a thread at the liquid cooling section, ans we'll be glad to help you, it would be nice if w stopped spamming this thread ;)Quote:
Originally Posted by marauder16
the thread is alreaady fifty pages of crap about this mobo, i dont see any reason why we cant discuss watercooling in it. (watercooling this specific mobo that is)
then there would be no need for any of the other threads, and everyone would talk about all aspects of PCs in one thread, using the arguement that its about PCs, so there for it belong here.
It would lead to a big headache.
Been testing with a pair of HyperX PC2-9200 kit on RD600 and just couldn't seem to get them to operate at 575MHz. I checked the heatspreaders and it had Micron D9GKX ICs inside. Couldn't even do 550MHz at 5-5-5.
Previously had no issues doing 575MHz with OCZ FlexXLC though. So the board is really picky with RAM and you have to re-tune it when swapping out RAMs.
Thank you :)Quote:
Originally Posted by pcmoddingmy
anyone use'n a hsf with the push pin clamping system like the stock intel hsf?
My TT BTvx bent the :banana::banana::banana::banana: out of my motherboard:eek: . Literaly to the point where my standoffs wouldnt line up with the motherboard holes if i installed it off my motherboard tray. Aparently when installed the tabs toed in when the the bracket flexed, this toe in combined with the clamping force on the motherboard was cause'n it because of the proximity to the outer edge of the board. I found this very unacceptable so i machined up a backplate today for it to straighten things out. And i had heard that the vx didnt apply enough clamping pressure:slapass:
If you are use'n a hsf with the stock style clamping system I suggest you take a look at the top edge of your board and check. After 4 days of use my motherboard had a very noticeable bend in it sitting on my bench with nothing installed on it. Made me very very uncomfortable.
My d9gkx is stuck around ddr1000 too, using cellshock, runs fine at stock cas 4, but oc'ing at higher cpu mhz limits ram to around ddr1000, for orthos blend that is. I will try my Crucial kit next, though that's a cas 3 kit that maxes out at around drr1000 anyway. I will see if it performs cas 3 better than the Cellshock though. Also I'm finding trc needs to be loose for orthos blend at higher cpu mhz, over 30 in fact. I am trying to toy with the preamp drive strengths now using 2t. There's so much to test on this board, finding the best overall performance point will certainly take a while...
regards
Raja
Thanks for the warning, Mongoose420. I'll be very careful with mine once I get it... Someday.
yea, scared the :banana::banana::banana::banana: out of me when i seen how bad it got. I noticed it flexed a lil when i first installed it but it was really bad this morning when i looked. Thing is ive never used the 86cfm fan that came with the VX. I could have saved myself $10 and had the factory bolt through kit that comes on the original big typhoon.
i´m using the microcool whisper xs now
http://www.forumdeluxx.de/gallery/da...pole_RD600.JPG
@ 1,5 i have reported 60°C idle and 65°C after 10 mins of prime v25.1
