Same experience here. I couldn't get 400x9 stable no matter what i did until I raised the MCH to 1.6V. Small FFT would run flawlessly but I'd get random BSODs and Blend would just reboot my computer.Quote:
Disabled C1E and now at 380 mhz....:toast:
This is probably a stupid question, but how does go about setting the 1333 FSB strap from the default 1066? Is this done under the memory settings?
I need some help about ICH7R and the Marvell controller.
I have 3 HDs connected to the ICH7R. Today I added 2 more HD and I connect them to the Marvell controller. BIOS version is 2395.
As long as there's HD connected to the Marvell Controller, my computer won't boot into Windows XP (Boot drive connected to ICH7R). It will display a black screen with a blanking cursor after post screen. (Lower right corner EB -> 0 -> blanking cursor on top left)
But if I connect the boot drive to the Marvell controller, it boots into Windows without problem.
Also it would not boot a XP setup disc when non boot drives are connected to the Marvell controller. It will also stuck at the blanking cursor.
Anyone else have similar problem/experience when there's non boot drive connected to the Marvell controller then computer won't boot into XP / XP CD?
Do you guys have any solution for this problem? Will try BIOS 2431 tomorrow, hope it will fix this problem.
Yes, change the reference frequency to 333(1333strap) in memory settings page.Quote:
Originally Posted by loafer87gt
Nice pics Chaos, I'm sure you get an excellent outtake vortex with 2 rear fans sucking away at your Tuniq :D
Do I ever hehe, those are pretty decent fans too. rated at 75CFM unrestricted.Quote:
Originally Posted by uberwurst
Originally Posted by shogo_ca
Lol I happen to like the look of Cold Cathodes, however too many of them isnt very appealing.
In the BIOS Boot menu, what order are the drives in? Are there any RAID arrays defined? Is the ICH7 set to IDE, RAID or AHCI?Quote:
Originally Posted by wa2000
I have were sometimes it hangs on a Warm boot with a BA post code.
Just hangs and beeps. Do you guys remove your DVD / CD from the boot order ? Is this my problem ? I have DVD, Floppy, and SATA hard drive in my boot order.
Originally Posted by FullMoon
Far as I know you cant remove stuff from boot order, except to disable like boot opticals or anything like that.
No RAID arrays defined. ICH7 mode set to IDE. In boot menu, the boot drive is the first in the HD boot list.Quote:
Originally Posted by gtj
It failed after 36 mins @ 3.9Ghz Large FFT...Quote:
I set it going again when I went to work at 3.8Ghz with 1.5vcore and it seems good. Im could probably drop that vcore a bit.
http://img401.imageshack.us/img401/3...hourhj6.th.jpg
this is on 1333 strap.
OK, this sounds familiar. I think I resolved the problem by switching to AHCI instead of IDE. The problem is that you have to reinstall Windows, use F6 and the RAID driver diskette (it also has the AHCI drivers on it). The good news is that if you run the setup and install over the existing windows install, everything stays intact.Quote:
AHCI is a better option anyway since it was developed specifically for the SATA interface.
If you wait a few hours, I can test the change from IDE to AHCI on one of my machines and let you know how it goes.
Cant do 3.8 stable with this board seens like this board doesnt like high fsb, impossible to do 4ghz (i did it with the 680I also did 3.8) cant do nothing close to 3.7 with this BX2 tryed 1066 and 1333 strap , with 1333 strap boot up to windows but very unstable, with 1066 post and go 1/2 windows and crash, no matter what vcore i put , im thinking on abit 680I , think im going to sell this board , sorry guys but i like high FSB, 401 is not enought for mi brain :) if anyone want to buy a bx2 PM me please
Thanks, I will try it after I move the data on the harddrive to somewhere.Quote:
Will try to set it to AHCI first, if still not working will try to reinstall Windows.
AHCI allows NCQ and Hot Plug for the ICH7. I updated after installing Windows in IDE mode by mistake. One thing I noticed is that, with the standard EIDE interface disabled, I got a BSOD. I never tried to boot with it disabled before doing the below before so don't know if that caused that particular issue. Doesn't matter to me because My DVD burner is EIDE so I need it enabled anyway.Quote:
Also Intel recommends setting the ICH7 to RAID mode (which, I would assume requires loading the RAID driver vs the AHCI driver in the steps below) since RAID mode also enables AHCI as well as allowing you to add RAID later without re-installing. I will not be using RAID so I just went with AHCI.
At any case I would recommend using Ghost or Acronis to image before doing any of this (good practice anyways).
I did this switch as follows (because I messed up and forgot to install in AHCI mode). (note that the REAL step 1 was to image my drive to a USB external before starting!!!) NOTE: this is with the BIOS set to what I installed as (IDE)
1. In device manager under "IDE/ATAPI controllers" I selected "Intel(R) 82801G SATA controller (I believe that was the device name, if not exact it's close), Right clicked and selected "update driver"
2. Told it not to search the Internet - Next
3. Selected "Install from a list or specific location" - Next
4. Select "Don't search I will choose a driver to install" - Next
5. Inserted Intel Raid Drivers floppy and selected "Have Disk"
6. Browsed to A: and selected the INF, then selected "Intel(R) 82801 GR/GH SATA AHCI Controller" (I think there are 2 AHCI and 2 RAID mode drivers listed, ensure you select the AHCI).
7. Let it do it's thing till it was done the IMMEDIATELY restarted going IMMEDIATELY (before Windows began to boot) into BIOS and selected AHCI mode.
8 Booted right up with the correct driver and no issues not previously noted (the PATA EIDE disabled issue).
Originally Posted by Ajfina
Try 1.7 vMCH &1.325vFSB.
I'll get my bx2 on Monday. I have a Xeon 3210 waiting for it and I'll post results sometime next week. :)
Which is why i didnt get why everybody was clammering for this board a couple weeks ago.
I asked multiple times if someone did high fsb with a 6600 at 9x multi and got no response. So its not a board i would recommend for most unless they didnt want to run too much over 3.6ghz. The newer week cpus are just that much better and if you have sufficient cooling your going to need more than 450fsb max.
I just can't get anywhere near > 3.5 GHz without complete instability. It must be my BX2's memory controller, because the instability stems from memory errors (windows memtest fails, ORTHOS can pass Small FFTs but never Large or Blend).Quote:
This is despite loose timings, plenty of vdimm and vMCH (I've tried em low and high, all to no avail), changing BIOS versions, strap settings, enabling/disabling C1E, EIST, Enhanced Power Handling - in every permutation.
At this point I think I'm going to try to return mine to tigerdirect or otherwise sell it.
Alright guys, need some help. I tried to change the strap on my xbx2 and it didn't boot. I don't have the slightest idea on how to clear the cmos on this thing. I've tried 1 stick of ram, I've took out the battery for a couple minutes, and played with the bios jumper, but nothing. my 8800gtx fan just runs at full speed. I appreciate any help
Originally Posted by hotrodtheman
Try moving the bios jumper to maintenance mode then turning psu off for 20 seconds and booting up. Works for me even in the most stubborn occasions when it refuses to boot after changing straps and trying a overly high overclock.
If it fails to boot when just trying a high overclock without changing straps then usually just turning th psu off for 20 seconds fixes it.
Yeah, physically unplugging the PSU for 20 seconds (sometimes in conjunction with removing a stick of RAM) often does the trick for me.Quote:
Originally Posted by Devious
do u think its worth for me to sell my xbx2 and go for commando? i got a very good deal here, around $225 (very cheap compare to other local retailers price ;) )
I just got an RMA from tigerdirect. I'm facing a similar question; get another BX2 or another board entirely (perhaps a commando).Quote:
Originally Posted by irenic
