Nice work OPP:toast:
Anybody seen any higher then this for an AMD setup?
250x11,, Kingston HyperX @ 3-2-2 Cas2.5
OPP
I don't know OPP, if I have I dont remember it..
Great Job:thumbsup:
great but this bench is better :confused:Quote:
Originally posted by umekami10
11.5X147
Memory timing 7-3-2-2.5
http://hem.spray.se/umeimak10/epoxnf...sandra/247.jpg
http://www.thenakedreview.com/forums...p?threadid=347
Barton 2500 AQUCA 0303VPBW
EPOX 8RDA+
2X256MB TwinMos PC 3200
HD :IMB 30GIG-7200
VGA matrox 4MB pci
PS:Antec 400W
Cooling: Prometiea
Win 2000 pro
Vddr: 3.02V
VDD :1.9V
Vcore:2.1V
249X10.5 Aggressive
Timing 7-3-2-2.5
UMEKAMI
http://hem.spray.se/umeimak10/epoxnf...-7-3-2-2.5.jpg
what cooling do you guys have @ southbridge when hitting that high fsb?
hey OPP, I've got the nf7-s ver1.2 - I cant cant even get it to 250 single stick let alone two sticks at any multiplier. My board is vmem modded and vdd modded. I've got a watercooled chipset and cpu. My temps dont go above 30c at any voltage. I have a decent heatsink on my southbridge, do i need any thing on any other chips? I have 2x 256 kingston hyper x, and an awsome 2100 t-bred "b"
Has anyone ever broke 4k with an amd system yet? Thats my goal:p
damn the best i can handle with my 8rda+ (unmodded)
and a stick of 3200xms is 210mhz fsb
http://www.pbase.com/image/14849956/original
thats pretty good, beacuse i have not seen so many 8rda+ unmodded go above 200mhzQuote:
cant even get 250single? its not many that have achieved that. btw you could try to add heatsinks on the mosfets beacuse they get really hot when overclockingQuote:
that was going to be my next step
finally got my 8rda+
1700+ (relabeled 2600+ cpu) tbred-b
got it too 2.4ghz with my coolermaster super silent air cooler :banana: 1.4ghz@2.4ghz sounds nice doesnt it? :)
can run 205fsb single channel without any mods
(twinmos pc3700)
how much does increasing the fsb from 200 to 240+ increase performence?
i get about 9000 points in 3d2k1 and 1333 in 3d2k3 with my radeon 9100(250/200...yeah thats right 200 and the memory wont oc a single mhz... :/)
to those who already did the vdd mods, what was your 3dmark score before and after the mods and ocing?
__________________________________________________
so far:200fsb single channel= 2843/2605 just bought the
innovatek chipset wb and the trimm resistor :)
2*OCZ El DDR PC3500
7-2-3 cas2.5
10.5*245.8
Windows 98SE
soon a best score in WinXP
http://membres.lycos.fr/cpulloverclock79/3806.png
http://membres.lycos.fr/cpulloverclock79/236.25.png
It runs with 237 7-2-2 cas2.5 on prime
http://membres.lycos.fr/cpulloverclock79/3811.png
the last bench
WinXP
http://membres.lycos.fr/cpulloverclock79/wow.jpg
I have a heatsink on the mosfets, other then that I have a heatsink on the SB and I use a 80W pelt on the NB.Quote:
OPP
nice... some more memo tweaking and youll be the first one to get 4gb/s scores with an amd system :)
third score in the world with an AMD system
second score ;)
Twinmos PC3700 instead of Ocz PC3500
http://membres.lycos.fr/cpulloverclock79/record1.jpg
cool, i got the same memory... havent done the vdd mod yet, nice to see what the memory can do... what voltage? 2.77 or 2.9?
2.9 and burn with prime in high priority (10) to test the stabilityQuote:
my system is stable at 238-240 in DUAL
hmmm i cant run it at 205fsb 5-2-2 cl2.... should i try again with more voltage?
do i miss sumthin or why can everybody set 250mhz fsb on the abit nf7-s? i saw in many reviews only 237mhz fsb
Nice clocking there cpu....:toast:
