Dual core pwned by older single cores in multi-tasking?! :stick:Quote:
I'm just having a hard ass time finding a board for my conroes, i just wish they would release them already, not to mention if anyone knows any boards that will for sure be kentsfeild compatable i am very interested in that as well, i would like to just buy one board for conroe and kentsfield.
im pretty sure FCG posted that intels 975x badaxe will support kentsfield, rev 304 that is...Quote:
Originally Posted by Anjelous
Hmmm i must look into this a little more, if that is the case then i will only need to buy one board, and its already been released....then i can get quad core goodness started adn post some benches for you guys.Quote:
Originally Posted by Ldawg
Mmm quad core goodness in a matter of months :)
I have the D975Bx ver 304.
I need to find a conroe :confused: :(
And 2 EVGA 7950GX2's on their way.
Hehe Maybe for you, if i can get a board, it will be quad core goodness in a matter of weeks/days.Quote:
Would be cool with an excel spreed sheet of all mobos that support conroe :)
I Second that! The sheet could have seperate columns for features (eg:- Sata, PCI-E, Max Memory Supported, Chipset etcetera) and Prices. Hmm, i could work on creating such a sheet, but would need help in filing it in with values and Specs that i miss.Quote:
Originally Posted by Nosfer@tu
Mickey
Does any1 know if the ASUS P5WD2-e Premium rev.2 will support conroe, or only rev.3 will support?
tkx:)
Quard core is at the VERY erliest Q1 2007 but more likly in Q2, motherboard manufactores have them allready thoug :)Quote:
TO the best of my knowlige!
Boards marked with BOLD support conroe.
Intel D975XBX (revision 304 and greater) motherboard with latest BIOS ("0618"/1009)
Foxconn 975X7AA
ASUS P5B & P5B Deluxe
P5WD2-WS/P/E Rev. 1.03 boards should have a new pwm buck controllers that supports VRM11 standard.
ASrock 775Twins Revision 2
DFI Infinity 975X
P5W DH Deluxe
What about
MSI 975X Platinum ??
Gigabyte GA-G1975X ??
ABIT A8WD ??
ABIT Fatal1ty FP-A9D??
ABIT AW9D ??
Albatron PX975X ??
ECS PF24 ??
I've started the Spreadsheet and put it up in "The Motherboards Spreadsheet Project" thread here. Hope people get interested and help it grow.Quote:
Mickey
Accualy. All I want to know is what board has most modding potensial, Vdrop and so on.Quote:
Originally Posted by mickey79
And what has max fsb.
I will cope with the fact that it only has 2 x Sata or 1 IDE :)
you robbed a bank ? :woot:Quote:
Originally Posted by beast-usa
Any news about DFI Lanparty 975? ;)
I have a 6600 on the way and was getting ready to order a Foxconn 975X7AA but on NewEgg I read this: "Revision AA does not support Conroe. Revision 975X7AB is on the way, and will offer more overclocking options (Memory Divider Options) I should have the CPU by Wednesday and want to make sure the mobo I get is compatible.
Hi guys !
I dont know if this is obsolete info to you, but anyway
here it goes:
I have an Bad Axe ver 302 with ADP 3189 buck controller on it.
I checked its specs and finded out that it does support VR11.
http://search.analog.com/search/defa...+3189&local=en
FEATURES
Selectable 2-, 3-, 4-, or 5-phase operation at up to 1 MHz per phase
±7.7 mV worst-case differential sensing error over temperature
Logic-level PWM outputs for interface to external high power drivers
Active current balancing between all output phases
Built-in power-good/crowbar blanking supports on-the-fly VID code changes
Digitally programmable 0.5 V to 1.6 V output supports both VR10.x and VR11 specifications
Programmable short-circuit protection with programmable latch-off delay
APPLICATIONS
Desktop PC power supplies for
Next generation Intel® processors
VRM modules
So is there any chance at all, that Conroe support will come
with Bios update ???
Or is it just those resistors and capacitors which will do the trick ?
Because i thought that D975XBX was originally designed for Conroe.
Wasnt Conroes "nickname" Bad Axe at in some early design stage ?
( The register 2004 or 2005 if i remember ).
I hate to buy a new mobo twice a year, cause they cost ~250€ +
shipping here in Finland.
- MTP69 -
I'm in a similar situation as you. I'll be getting conroe at the end of the year and I'm waiting for a Core 2 Duo/Sli ready Mobo.
Until i get conroe i'll probably get a Pentium D 805 and overclock the hell out of it but as you, I first need a MoBo that supports conroe.
I got this aswer from Asus, when I requested a Core 2 supporting bios for my reworked P5WD2-E board:
"After checked with our RD, due to the normal life circle of our product, P5WD2-E Premium doesn’t support Conroe before PCB 1.03G rev.
So even you change the VRM, due to the circuit limitation, the 1.02G rev motherboard still will not work with Conroe CPU."
So it seems that asus will never provide a conroe beta bios for p5wd2-e even for testing with modded boards :) . So Roger after all ,,, conroe & p5wd2-e = no go ?
Before PCB 1.03G rev seems that p5wd2-e+conroe wont work. Clear as water...
@ The Stilt: how did you rework your P5WD2-E ?? Im curious :p:
- Certain pin of PWM Buck Controller liftedQuote:
Originally Posted by ^don.k's^
- Lifted pin connected to certain voltage
- Certain voltage connected to certain pin of the socket
- Certain pin removed from the socket
- Few added resistors that connect certain traces
That was pretty much it.
Before the rework diagnostic card gave only two slashes (which pretty much means nogo). After the mod it just hangs because of some bios issue.
I am pretty sure that it would work with proper bios and according to certain mb engineer it also would ;)
Mmmmyeah. Proper application of certain soldering iron. :)
I'd love some info, to start working on the AW8D engineering sample we've got...
Originally Posted by The Stilt
So close... ;)
Need that BIOS though...
