Originally Posted by p4l1ndr0m3
In theory, you are right, but as I said, there is a FSB problem that is due to the bios for this RD580 board being in their infancy. I'm not joking about the 40mm fan though, whether you OC or not, its definately a good idea. The heatpipe is great, but when you can lower the temp on your NB a good 10 degrees C for only 4 bucks, its a no brainer... Also, don't be afraid to raise the NB and HTT voltages by 0.1V or so. Just pay attention to your temps under full load, if you aren't comfortable with them, turn it back. Also, the 40mm fan should help to take care this. Lemme know when you get your board and I'll be happy to help you set things up the way you want.
