:slapass:
hey men~ this review result is just another sudhian review and standard mis-leading promotion technique of Zalman, they test the VF900Cu in max fan speed and get the temp after finished the test. But for ATI stock and AC accelero, they just using 50% fan fan speed and get the max temp during the test.
see this link and you will see extact the same result:
http://www.sudhian.com/showdocs.cfm?aid=743&pid=2929
I also tested the temperature of X1900XT with ATI stock cooler,AcceleroX2 and VF900Cu by 3D marks 06 and recorded the temp result by riva tuner 15.8(unlocked support for X1900)
Just give you guys a result summary
ATI stock cooler(5060RPM) at X1900XT Full load: 69-70C
AcceleroX2(2100RPM) at X1900XT Full load: 65-66C
VF900Cu(2600RPM) at X1900XT Full load:75-76C
You can check here, more and more victims are complaining their VF900Cu and they also get 75-80C withVF900Cu@X1900XT(X). Most of people were basing those zalman lying result to choose their cooler.
http://www.ocforums.com/showthread.p...44#post4412244
http://forums.guru3d.com/showthread.php?t=176582
So, those commerical site rubblish reviews are craps, I just believe end customer's comment and review.
FYI: I'm keep using the AcceleroX2, now the max temp is still 64-65C at load. The temp is still not good enough because I expect the temp should lower than 60C.
But if you looking for cheap HSF, Accelero is your good choice, just $29, while VF900Cu is $50 but the performance is....
