This one's mine ;)Quote:
-26C core temp according to BIOS, CABYE 0540 FPMW. No cold bug encountered as of yet on dry ice.
http://img222.imageshack.us/img222/3210/18pb.png
WOW... :slobber:Quote:
Originally Posted by s7e9h3n
So, either your autocascade was colder than ever or you were using something different. :D
Opteron 148 CABYE 0543FPMW
Slight cold bug on mine, have trouble passing 300MHz HTT. It got really bad when I removed the IHS and I got lots of hard locking at idle temps around -30ish, so I have since reattached it. Runs no problem at 11x291 24/7 with no bug.
It's all cpu ;)Quote:
OK guys its time consuming but i've updated up to page 4. Note's of interest as of late are some interestng X2 chips floating around with the stepping LDBFE. At this point in time there is no sign of coldbug however none that i know of have been tested beyond -35 cpu temps..........A volunteer to send one to Stephen or I for xtreme cold testing would be appreciated. Would rather it go to stephen as he can pull colder then I can with more consistent temps.
*edit* Dumo would also be a good candidate for max cold to test this cpu..........
I can test it:)
Opps, no I can't....no mobo/mem left.
I can arrange for a temp mobo and ram for you dumo......... sapphire RX480 and 2x256 bh-5 suit your fancy?Quote:
Originally Posted by Dumo
You're not talking about my preciousssss are you lolQuote:
Originally Posted by chew*
http://xtremesystems.org/forums/show...&postcount=122
I'd be happy to test that for you - I'll even let you choose what type of memory you'd like it tested with :D BH5, UTTBH5, TCCD, AENON, or basically any other type I'll have access to ;)Quote:
Originally Posted by stone_cold_Jimi
actually yes that chip or another with the same code in particular :)Quote:
A64 FX-55 @-17 (no coldbug)
CABCE TPMW
booted with evap at -32, no issues.
CABCE - CBBCE would make it a 512K L2 FX55 :p:Quote:
Originally Posted by Alec
Gah, soz... Spent last 4 hours mounting evap so it made decent contact and am now nackered :stick:Quote:
Atleast I get better temps than I did before, though :rolleyes:
Thanks for pointing it out, I probs wouldn't have noticed it otherwise...
I may have seen the demon this morning - I booted at 345x9 same as yesterday and left it with only Firefox running while I went and put the kettle on. System froze while idling. Ran over 3 hours of dual SP2004 while multitasking on the desktop to check, no instability whatsoever. That's a temperature feature or I'll eat my hat.Quote:
Now 3:20 into 2 Rosetta jobs, average -8C to -10C. Perhaps I'll run 310x10 later and see if it locks up tomorrow.
Small update on my stepping CABCE 0522 XPMW -84 evap -50 is core I think
3700 sandy.
KAB3E 0548 RPCW buged @ 6*c at 3160mhz
3800 venice
LBBWE 0532 CPAW buged at any temp to 2700mhz
Hi
Is the Opteron 165 CCB1E 0605XPMW Buged?
THX ;)
Add more data to the thread: my CCBWE 0517 MPMW 4400+ is fine for core temps down to at least -28C.
More than likely - B1 mem controllers are notorious for bugging.Quote:
Originally Posted by Dogimann
X2 3800+ LDBHE 0601 UPMW, it can easily handle -20 C* haven't got the equipment to go colder. Gonne try some DICE soon and see how it does.
3800+ Manchester LDBHE 0601TPMW Idle -26C Load -10 Under Stock VapoLS 3.3GHz benchable @ 1.63v, 370+HTT possible
3700+ SD CAB2E bugged even at 0C.
Opty 146 CABYE 0540 FPMW
bugged at 275htt @ -30 celcius (cpu idle)
Phase is broken cannot test anymore...
urgent!
is 170 0550vpmw ccb1e bugged??
