Be aware you may not need 2.8 volts. The set I got from RMA 3 weeks ago are working happily (so far) :rolleyes: at stock speed of 250 MHz at 3:3:3:8 on the lowest voltage setting my DFI will take - bios set to 2.5 volts with the 0.3 volt bump disabled, SmartGuardian shows 2.43 volts. My last set took 3 months to fail so it may be a while before we find out if this strategy is effective. Micron gave these things a lifetime guarantee so I intend to run them until they break, and RMA each time they do. I have a set of G. Skill HZ in reserve to cover the gaps.
