There's nothing better then SLK 800 (also unavailable here in Slovenia), so I guess I have to build it myself. I just love a good challenge :D
Now you just need a SLK-800 for comparison :p
Maybe I'll have to get 1 to you someday ;)
:D very good :D
d'oh.. you should have made a slim fin copper version of the Thermalright AX7 or GlobalWin TAK68 with 80mm fan on top instead of sides.. hehe 8-)
I'm sure the air cooled rig will be interesting also for a comparison.
But what does your O/C stand at now with the latest block revision? Also water and CPU temps?
Is the cold weather holding up for you where you are?
Morphling1 : Going where no one has gone before on water.
:toast: :cool: :slobber: :D
I took I little breather from overclocking, I need to make some blocks now :D In the mean time I'm folding at 2.55 GHz 2V 20°C water (new block) 36°C load internal diode (8k3a corrected).
I will be back, just finish new top for my GF4 water block so I'll put it in tomorrow than some real overclocking begins in w2k and cold air blowing on my heatercore :D :D
morphling1
That a hell of performance for a waterblock. I will be glad to see a test against cathars block. I think yours is beter. Wouldn't your c/w be around 0.10°C/W? Keep up the good work on your blocks =)
BTW this is my first post at xtremesystems =)
Thanks, and Welcome to xtreme.
I reply you PM and I'm tomorrow I'll rerun my diode calibration calculations like I describe to you. With tbredB I would have much more accurate temps with any other board, but if that calculations work then I'll trust my 8k3a again, for now I rely on my stable OC: :)
welcome :D
Well, you could always set the processor up at the same settings in a diff puter and compare temps using the same cooling.. as long as your close it should be withing a degree or so..? 8-)
wow, just noticed this thread ;)
AWSOME OC!!!!!! a 1422mhz chip doing 2700mhz+ incredible!
and i love you waterblock design too...any chance of more pics of it?
Someone drop a vapochill/prommy on the thing already, or some LN2..! 8-)
I couldn't wait until I was finnished, but my cutting tool became dull so I couldn continue but anyway here it is almost finished.
http://www2.arnes.si/~mlivak/Air%20c...0air%20003.jpg
http://www2.arnes.si/~mlivak/Air%20c...0air%20004.jpg
http://www2.arnes.si/~mlivak/Air%20c...0air%20005.jpg
Still need to make shroud and finish cross cutts
I'm just testing that other 1700+ I'm currently at 2250 MHz 1,85V air cooled prime95 stable :D pretty good temps are 33°C with 20°C room in socket diode on my old 8kha+ I will try higher overclocking soon with higher voltage too, but I need to unlock that 13 and up multy because I can't realy get stable past 180 on this mobo.
goood temps.. :D
send one to me, ill test here in brazil with room temps at 40ºC :D
Ouch 40°in the room, I would be melting, I feel hot if my room is 25°C :D
Here it is after one hour of prime 95 temp very good overclock stable. I couldn't take screen shot because I'm not connected with that computer and no floppy either so here the real screen shot :)
http://www2.arnes.si/~mlivak/Air%20cooler/testing.JPG
Lookin good, lookin good! You definitely need a SLK-800 to toy w/...I want to see a morphling1 air-cooler vs SLK-800 :D
:D
damn nice dude, you just made me order a tbred b.
Do you change your fsb in windows ?
I have the same motherboard what program are you using?
Nice oc btw ;)
Have you done any vdd mod on the board? if sow what is it on ?
R
SetFSB is the program to have if you have Epox mobo.
I did vcore mod on the board is that what you asked?
It's pretty simple, I can take pictures later if you want.
ohh
I thought you had a Ep-8RDA+ :) nevermind
Why is the SetFSB so good ? To lazzy to oc do it in windows insted :>
R
Set the voltage, prime, if it fails, drop it back. It is the most simple method of overclocking/testing, and cuts out shutting down/loading the bios/booting to windows.
softFSB is available for most Motherboards that have common chipsets.. KT266/AMD761/KT266A/KT333 etc etc
search these forums for more info
search in google for "EPOX setfsb"
SetFSB homepage:
http://www.page.sannet.ne.jp/k-hazama/software-E.htm
