Now that sounds better. :toast:Quote:
What boards are you using? DFI nf3-250? My tforce sucks big time. HTT limited at only 285 :/
What? Theres something wrong then. I've had my Biostar up to 384 HTT,and then my 2800+ crapped out (no multis to drop). I own the DFi NF3 250(Crappiest board ever),Chaintech VNf3-250,Asus K8N-E Deluxe,and an ABit KU8,and the BioStar destroys all of the others boards by alot.Quote:
Originally Posted by Fr3ak
Well I put as 5 on the NB and SB, but that didnt make a change. I am running 284x8 with stock volts, 286 makes windows crash, even with 1.7v, so I guess it aint the cpu. Too bad you cant change chipset voltage. That might help.
I wanna get another sempron 2800+ rig and I am not so sure if it is worth getting another tforce as it seems like its a hit and miss :/
Both of my 2800+'s are running in DFI LP NF3 250GB's.
yeah im using dfi board too. picked up another chip today too. older stepping, see how it goes. post pics and results later if i get time.
Sounds like a bios issue. You need to use the cr51mb02. It has all of the newest memory settings,and will solve your HTT issue.Quote:
http://www.biostar.com.tw/t-series/d...tails.php?id=1
There are some more here. http://lejabeach.com/Biostar/6100-939/6100939bios.html
I'll try BioStar TForce 6100. Maby it will be NEW WR :)
whats the full cpu stepping of your chip? is it an lbbwe?Quote:
Originally Posted by fr@me
I am already using the B02 bios. Didnt make a change at all.
I had now 2 tforce board, one was maxed out at 270 and the other one at 285. Hopefully the third one will be better.
Da tu prosto molodec =) nice job!
nice overclocks. even at 1.6v my D0 sempy won't go higher and i don't want to push the voltages any higher.
Did anyone try to put an xp90 or a sonic tower on a naked Sempy?Please report in and one more thing what is the hight of the core since I wanna order a shim made of cooper.
My XP-90 is on a naked chip. I made my own hold-downs using a bolt,and a spring,so that pressure would not crush the sides of my die.Quote:
Originally Posted by AsAsIn8eR
The first two photos are on a lidded cpu,the last is on a naked chip.
http://img.photobucket.com/albums/v2...idemounted.jpg
http://img.photobucket.com/albums/v2...declose-up.jpg
http://img.photobucket.com/albums/v2...0/SIMG0009.jpg
LOL!It's so obvious you have a cat.How does that Biostar peform??Did you use any shim or smthn?I personally would like to buy smthn with 120 mm fan.I like it to be silent but performance as well.
n1 to the subject :toast:
why isnt your 12v connector plugged in???:slap:
Because I solider the +12V. connector to the back of the motherboard. :fact:Quote:
ahah, nice, do you see any clock increases from that?Quote:
Originally Posted by oicurafox2000
Absolutely not,however it is more esthetically pleasing in appearance with no 12+wire in front of my mobo. :)Quote:
WeStSiDePLaYa
LBBWE0528UPMW
Nice read guys. can yall tell me what the max vcore you have used. Also Frame WHAT VCORE YOU USED TO GET TO 3.0+?
How do you interpret those numbers?I have LBBWE 0530CAA(strange I only have 3 letters.)
there is another letter in the 3rd row
I have a LBBWE 0548GAD
X03889....
or is the X already part of the serial number?
Looks strange indeed.
oicurafox2000 did that mod require dremeling the xp90?Or that plate that contains the screw was a fit there?Cause I see that the original xp90 has a channel where the clips stay.Thnx and some pics would help me!A how to..!
