It'll hang over a little, should be able to attach though.
hmm, i also have a fan controler I forgot packed away somewhere. Perhaps tonight I will try it with my 90mm tornado just for kicks.
I'm sure as a temporary "test" it could be done, use wire ties.Quote:
Originally Posted by gunit
We found the stock AMD64 cooler fans, 70MM to fit the GTXs perfectly - however 80MM fit too. If I were buying one I'd say 70 or 80mm fan would work perfect. Personally I prefer fans about 28 Dba and lower.
Dean
Alright, mine is ordered! :)
**crickets******crickets***
Everyone must've went to bed... :(
I should have my X1800XL from Newegg on Wednesday. Can't wait to slap on the modded 70mm / with fan controller fresh from my 7800 GTX (I just installed the NV5 Silencer Rev3 for the 7800GTX). [I really can't wait to get an X1800XT 256MB BIOS to flash it with.]
Also, www.ZipZoomFly.com has the BBA for $379 Free 2 day shipping!
i cant even unscrew the screw holding on the heatskink cover. Im using a small flat head and the screws yes are for philips type, but flat heads have always worked in philips type screws. With the pressure im applying I doubt even a philips head would work. what now?
Hmm I'd have to see it to tell. I have a small phillips screwdriver - hopefully that can remove the screws. Are they really that tight, or are you just having a problem getting the flat head screwdriver on the head to remove it?
http://www.bit-tech.net/content_imag...l/heatsink.jpg
Bit-tech managed to remove it. "...eight small screws that attach the top plate of the heatsink."
http://www.bit-tech.net/hardware/200...x1800xl/2.html
no, the flat head makes good contact. its almost like they are glued into place.
No need, theirs nothing wrong with ur card. ATI Tools reading incorrectly.Quote:
Originally Posted by Atomicpineapple
Im even getting artifact errors on stock speeds :slapass:
Would u disconnect the stock fan on the card? Or do u run both?Quote:
Originally Posted by dnottis
Thats too bad, I'd really like to see some close up pics of that cooler / heatsink. Seems like the fan pushes air into it, different than the heatsink that is under the face plate of the 7800 GTX. Still blowing 25 - 30 cfm on that copper plate cannot be a bad thing. Maybe an after market Zalman will be the way to go with the X1800XL.
The GTX had a regular heatsink with fins and then the fan, so we'd disconnect it and just pop a 70 or 80mm fan on there. This is like a housing so there may be an advantage to using both.Quote:
Originally Posted by mR Yellow
Not my pic, but this is just what mine looked like. The GTX has a heatsink with fins so the design is different.
http://img384.imageshack.us/img384/431/pict02676rs.jpg
yeah there realy is no room to push screws into. maybe ill just get the zalman one after all and take of the whole heatsink.
Gunit Last time I tryed 1.225 it also gave me lockups. But i will try it again. I will alst try to lower my memory speeds and see what happens. But i find it odd it has a max on 1.2v may me sapphire locked it somehow ? May be a XT bios will help me to get past this wall ?>
Anyone of you noticed any shimmering in WOW or other games ?
Read on another forum and the dude said it was alot.
But i havent heard about it anywhere else.
no, no shimmering in HL2, Q4, Tribes Vengeance or any of the 3d benches i testsd.Quote:
Originally Posted by Ubermann
http://www.hardwaresecrets.com/article/229/2Quote:
wire tie trick :)
use them to secure the fan.
From this pic it's clear that is a heatsink with fins.. I think the GTX trick will work just fine.
http://www.hardwaresecrets.com/fullimage.php?image=2154
He must've been talking about the GTX lol, I cannot stand the shimmering with mine. Drives me nuts!
lol. thats what u get when u go nVidia :stick: :slapass:Quote:
I haven't noticed any shimmering on my x1800XL. :woot:
I will try this fan trick tonight. I have 2 stock AMD64 cooler lying at home. :D
Just watercooling and dont bother with those ghetto attemps at modding the stock cooler ;)
The shimmering can be read about here:
http://forums.anandtech.com/messagev...&enterthread=y
I hope someone can check it.
I got mine for 379. Oc like crazy, owns any stock 7800 GTX. Shimmering is just in WoW. If it was in any other game review sites would have pointed it out instantly. Its a bug, it sucks.Quote:
lol. Im so glad i didn't buy the 7800GTX. I almost did.Quote:
The only thing that sucks for me atm is the drivers. They still a little buggy.
Thats why it got me wondering cuz i havent heard if elsewhere.Quote:
WOW shimmering is nothing i care about.
Think we can leave this issue behind us then.
