What type of cooling?I think it is in water, caused by not enough voltage :)Quote:
your old x800 is R423?Quote:
Originally Posted by ZX7891
Mine wont even do 500mhz stable WTF?
Using ATI Tool 0.24...tried different versions. It just locks up past 490-495... :slapass:
ouch, at least you got the other quad opened
What does it mean?Quote:
Originally Posted by TinTin
TinTin,
Do you have 3dmark01 scores with the card?
Regards,
Matt
Hong Kong I believe.Quote:
Originally Posted by Drow
Yes, Hong Kong, priced: HK$1990 / 7.8 = US$ 255, the seller has raised HK$100 from the original price :mad:Quote:
Originally Posted by Vapor
:)Quote:
Originally Posted by Matt Hirst
TinTin,
Thanks for that, gives me something to aim for.
http://service.futuremark.com/compare?2k1=8745823
regards,
Matt
Yeah, it's under a Maze 4. I could probably bump the voltage for another 50MHz or so, but I'm not sure the risk and effort are worth it. All in all, I wish I had your chip but I can easily live with 590/615. :woot:Quote:
-aMp-
Yes, I think my X800GTO2 is good!Quote:
But the 3200+ I got is a bad overclocker, can't do 2.4G at default voltage and maxed out at around 2.6G :slapass: :D
I did V-mod my 9800XT for a few hundred marks, if you like, just do it~ :)
Indeed, your card is not bad!
Have a Sapphire X800GTO² thats stop with my core 540. No artifacts, the screen just freezes.
Do any of you have a explenation of that? Its just wrong, that artifacts whont show before it crashes..
Big thanks!
My GTO² won't overclock very well. I get artifacts at 540 core but memory is good at 630!!! Running currently at 535/630 but I have not tested memory any further yet (using Zalman VF-700Cu).
time to vmod ! :D
Anyone reputable here willing to do a vmod on my GTO2 for me? I'd just like to be able to run it 24/7 on air at 620+ on both core and mem. Currently at 535/600 24/7.
not sure how but someone must have a guide out there showing you how to vmod the thing
http://imageevent.com/marginjohn/viperjohn :fact: :DQuote:
Originally Posted by coolmonk
As I wroth before, there seems like a block software manufactured of some sort..
Anyone heard about such tricks?
Cheers!
Becous, it wouldnt suprise to see the company, block this sort of thing to rise the orginal x850 - PE etc...
