Originally Posted by hipro5
Yes,it was a typo for LH.this is the main test which im interested for. thanks.
Im waiting your results.Your XTPE looks like a killer :toast:
http://img206.imageshack.us/img206/8908/28s8kh.th.jpg
Freq is here http://valid.x86-secret.com/show_oc?id=43995
Cooler is TT Sonic Tower with Papst 120mm@700 rpm
hipro5 impressive numbers,i'm deeply impressed! :)
you beat memesama!
ciao kiko! ;)
i also agree with Hipro5 that maxmem is no good for dothans and i don't know why but i always get better results with XP SP2 that Server 2k3..
somebody made some tests with SP1 for 2k3?
http://img187.echo.cx/img187/7383/utt2509pw.jpgQuote:
I think your chances to run >240 FSB 2x512 UTT in a C800 are close to zero,but we never know until you try it.
http://img236.echo.cx/img236/5786/snap2606dg.jpg
Mtec UTT on 875..
it's true that with dothan is more difficult that P4 but u can never know.
Hipro got insane rams , best bh6 I ever seen in my hole dirty life :D
btw what cooling do you use for the memory? voltage?
I use these heatsinks...........
http://www.thelab.gr/images/Hipro5/Memory/Modd_39.jpg
........and above them, there is the ABIT AN8 Fatality's Ram cooler with 2 x 4 x 4 DELTA fans @ 10000 rpms to cool them......Vdimm for maxing out on 875 chipset, is 3.63Volts...... :D
WinXP SP2 here too...... ;)
Here is my best on air so far:
Asus P4GD1 unmodded / Dothan 740 @ 1.52 Vcore /2x512 Mushkin Redline & DDR Booster @ 3.4 Vdimm
http://mrlobber.svnets.lv/Oc/221005/...6x11mhz_sm.jpg
CPU limited because these Redlines can complete Superpi at least at 267 mhz.
hehe,a same 2820MHz on P4GD1,730 dottie with cold air.
Originally Posted by RoyaL
Royal - I think these are the first 512MB sticks UTT based memory who run over 240 in a C800.Impresive! Tried myself few 512 Winbond UTT(Twinmos) in a P4P800-SE and never make it over 225.But in GD1 they were flying at 250.
I really have to dig out a C800 to play ..
No, 6 Mhz extra actually :p:Quote:
Originally Posted by sangboy
Would 25 fsb be worth the 0.5 sec difference or have you done some special tweaks?
dunno,never tried with 11 multi.
just known normal pi tweaks
my little 760 with the stock asus ct-479 heatsink & fan
cpu: pentium m 760 @ 311x9.0 @ 1.60v (bios) not modded yet
ram: 2x512 mb khx 3200 (bh5) @ 5:4 249-5-2-2-2, vdimm @ ~3.25v (real)
mob: asus p4p800-se with bios .003 and asus ct-479
gpu: either my pov 6800gt or my sapphire 9800xt (rip now) :(
psu: ocz 520w powerstream
pat: partially enabled (boot at 240x10.0)
http://www.abi00.de/silversurfr2/pic...%201,8vagp.png
I puted my DOTHAN 770 on my hi-pro-mie(R410 gas) and benched @ 3205MHz......Rams at 267MHz 1:1.....NOT my good mobo though......This mobo is my other P4C800E-Deluxe...... ;)Quote:
ALSO VGA @ 634 Core and 641 Rams........VGA on AIR..... ;)
http://www.thelab.gr/images/Hipro5/D..._41080_png.png
C O M P A R E URL.......
great! i bet it's homemade by you! Great modder for real ;)Quote:
what's the temp of ram when u bench'em?
like i said,you can never know. anyway with dothan it's quite impossible to get that mhz with UTTs..P4 it's a different story,even the bios don't helps too muchQuote:
Rams where at room temperature cooled by forced air(DELTA Fan 12 x 12 cm 200cfm).... :D
http://img.photobucket.com/albums/v7...sudason/25.jpg
730 cooled by Zalman 7700CU.
Hipro do you have pics of how you mounted the prommie on the ct-479?
Thanks,Hipro5. Excellent work. :toast:Quote:
Very usefull compare between P4GD1 and P4C800.
Looks pretty close.I cant belive the only difference in LH its 1 FPS.
From what have I notice so far benching with AGP mobos - raising AGP frequency helps for DL,DH,N in 3D2001. BUt it also lower your score on the non-GPU dependant tests. I presume you were running full PAT,right?
In this case you cant lower AGP freq. between tests.
I used MPS Uniprocessor tweak for my 2k1 run. Have you? Or the ACPI tweak?
NO full PAT involved........Boot @ 240MHz and into windows raised the fsb up to 267MHz......On this mobo, when I put in 865 Tweaker the 111(11) config for full PAT, it lets me bench on air @ 253MHz and on phase change @ 258MHz max........My other mobo lets me play full PAT on air @ 262MHz and on phase change(haven't tested it yet) should be around 267MHz+(I hope :) )......ACPI Multiprossesor run....
267MHz and 101(10) on tweaker = 245 - 248MHz with 111(11)......... ;)
Tommorow I'll test at the same frequency and full PAT to see how it does compare to this run.... ;)
http://www.thelab.gr/images/Hipro5/D...seal_1_jpg.jpgQuote:
Originally Posted by Elisha
http://www.thelab.gr/images/Hipro5/D...seal_4_jpg.jpg
are those custom brackets?
and did you solder the power pins and the fsb jumpers?
Yes........
......and yes....... :D
I have a FX57 that does 3.2Ghz on air with a sub 25 sec 1m SPI. :D
First class work again Hipro. :woot:
Any chances of a 780 in your future? ;)
MPS Uni should score higher than ACPI multi on a Dothan, but not by a significant amount.
Soon........very soon...... ;) :DQuote:
very ingenious way to pass the anoying ct-479 :).I would really love to see some close-ups with your mounting prommy.In the "http://www.thelab.gr/images/Hipro5/DOTHAN" folder i cant find one.
Kudos for your work,my friend !
