Originally Posted by SikaRippa
I have seen so many BS's, so I think that when you still can hear some sound or/and see a mouse pointer it is NOT BS, but something else. Also freezing is not BS but only a complete shut down. BS is hardware problem, simply because so many people (like me) has encountered it with a number of computers/software/drivers/etc - and it is allways the same.
Maybe you and markiemrboo have the same (new) different problem ??
Have you made a BS-test with Skiapline-demo (see instructions in first post)?
If possible DO it, beacuse GW6800le version 1 -cards USUALLY make BS with the test. I think you should have that version, because it is over half year old and has "4 3 470 6E"-caps.
'The faulty caps' is JUST a theory and I am (now) investiging what OTHER aspects (=components) can cause BS. Even if the theory is correct SOME/MANY capacitances having certain codes CAN meet the specifications - we have seen that e.g cards having "4 8 470 6E'-caps run very well when new, but fail after some (2,3,?) months.
About figure of your card.. if you think it is exactly the same as in document, maybe is not required. But if you have a better quality figure it could be inserted to document... if you have: please comment and I will send a private message for you with instructions.
