zabomb, as bloody pointed out, you are just not reading the information correctly.
head pressure of the pump, and the system pressure are two entirely different things.
I said 100CFM fans.. not 100CFM through the rad.. If you can get 100CFM through a heatercore.. well more power to you.. but if you did you would need one seriously powerful axial fan or a good blower fan.
but in the same regards, the HE series rads are very airflow restrictive.. I dont remmeber the exact number, but the FPI is in the 20's when I measured Noldor's 120.3.
In my experience I have been able to get a bit more performance out of the 2-199 than the BIX, but its not a huge difference.
for moonlights sake, I will do a comparative test between the two..
