1.72V didnt seem dangerous to me with my cooling and no load....
Thank you Juliette, seems someone was listening:DQuote:
Originally Posted by Juliette
RMAing after smoking your card because of your own doing is a definite no-no. You should not be talking this stuff as it could make manufactures not too happy with the site owners.
Randi:D
Listen, I don't pass along advice without having some knowledge of the situation my friend, if I mention such things its because I don't want to see guys unknowingly destroy hardware. I know we are in the heat of competitiveness.....its not that I was trying to prevent you guys from getting ahead, its that I wanted my competitition to stay around longer than 1 day:DQuote:
Originally Posted by skate2snow
Randi:D
well i even ran with the stock cooler that time so i think it wouldnt be any problems rmaing itQuote:
i'm running at the limit of the blackscreen (vgpu max) , no pb for the moment.
Funny Artefactmark 2005 :D Green power :banana4:
My card back to live!!! I uninsulated putted the stock cooler it is now working.
I'm back guys!!! I'm gonna kick ya asses!!!:D
héhé :toast:
Mr icee , it's time to get your iron solder :D
You're not alone :rolleyes:
http://service.futuremark.com/compare?3dm05=605629
Nice job misteroadster:toast::up:
But the Captain's a tad curious why it took 300mhz more on the CPU to equal scores? Never-the-less a great effort on your part indeed.
I won't be doing any soldering till my review's done, but damn my man, its one thing to score but the same score:D I may not have to solder, just phase change my cpu to equal your speed or better.
skate, great to hear your cards ok, but still be careful with the volts:)
Onwards and upwards my friends !
Randi:D
Stock cooling? No wonder the card is no longer among us :p: How high did the temps go? I had 80C load under normal vcore and using stock cooling. Now with water and triple radiator I have 41C Max load.Quote:
Originally Posted by Snowman89
Cooling is a serious issue on these non-lowK cards.
i can lower my cpu and beat you if you want :)
yeah well i could max run 585 with the door open and maybe 10c room temp, hmm i think after 30min benching the temp was 84c without the door open, what card would you chose between the x700pro or a sparkle 6600gt?Quote:
mista mista, what may be thy card? Either way impressive. But Mr.Icee ia scaring me though, he does have a valid point in regards to the cpu.. But the CPU had little effect in my case, About 100-200 points in 03 max. I think serious OS and driver tweaking plays a bigger part :) Either way, that's still some good points.
Mr.Icee I have full faith in you :D
Just realised I don't have enough tubing + anti-algae to drain the setup and change tube length to take it out of the case :(
EDIT: Sparkle 6600GT and then modify the cooling solution, though without the use of arctic epoxy , nudge nudge :stick: Andy :D
Nice nice nice, congrads my friend:toast:
I can't afford to destroy my card before I finish the review, so later this week I'll give the benching more attention. You know I'm just busting you I hope, great job mister !!
Randi:D
PS. I'll take the challenge, lower your cpu to 10x260 and put me away:D
i know you card is a gem ;)
My cpu is a 3000+ , only 9X :D
Thx Mr icee :toast:
This will be an interesting challenge to watch :)Quote:
Originally Posted by MrIcee
Misterroadster, where do you buy those CPU's? Those you have posted in this forum had no trouble getting to 3ghz. Mine hs trouble getting to 2,7 stable :) You should ebay them more often :D
:D , i hate ebay , and i love those 3000+ :)
I bought them in paris.
There's a lot of computer shops near of my home.
Mr icee, with your VC frequency i'll have a poor score , i assume you're a good nvidia optimiser :toast:
Or The DFI is a wonderfull board.
May be Twice :D
i know the dfi nf4 atleast has a 9:10 multi option. just do 9x289, 9:10 for the ram to be at 260mhz. ;)Quote:
Originally Posted by misteroadster
But then he'll lose the 1:1 option. Mr.Icee could just lower his multi.Quote:
Originally Posted by pik-ard v1.1
Your lucky mista! In DK most CPU's only do 2,6 and the people in the shop are friendly indeed :rolleyes: Took me lots of persuasion to dig through the heaps of 0441 MPM chips to find something that isn't pre-destined to failure before it's even unpacked :( Lucky french. You know Caen right? (Normandy) I spent my summer hols there, and still have friends over there from this school exchange program. I of course take german classes so my french is limited to ":banana::banana::banana::banana: me", "you're ugly", "my name is David", and "I don't love you any more my sweetheart" :) And probably some other vulgar expressions :D
i haven't any DFI , i have a giga K8NXP-SLI :(Quote:
:D , yes apparently in france we are very lucky with Good A64 939 steppings , i ve buy 10 0448 SPMW for the french overclocker's , 3 0448 SPAW , i saved them from 1800Mhz torture :rolleyes:Quote:
Indeed. One fine day when I decide to go for a new CPU I'll force you to ship them either to DK or to my friends in FRN :)Quote:
Mr icee ---> just for you :
http://service.futuremark.com/compare?3dm05=606062
Impressive DDR clock , don't you know ? :D
hmm, i must have missed it, what cooling is on your 6600gt that is allowing it to get its ram up so high?
you've got over 100mhz ddr above me, and i thought my ram was insane. ;)
