oke bro ;) i'll do it 32m when i am free :)Quote:
here is my new ocz 4200el plat chugging along so far.... i think if my memory controller was just a little bit stronger i could have gotten 2.5-3-3-x but I just couldnt get 32m stable with trcd-3...
Added... Thanx a lot :toast:Quote:
Originally Posted by arctic-k20
Glad to see your long VX/bios/memory controller nightmare is over. They'll run cool and provide plenty of bandwidth and a lot less grief. :toast:Quote:
thanks gundamit......im glad as well....its nice to be able to turn off the computer and know it will turn back on every time now ;)
this is 7+ hours goldmemory 6.64 stable (and prime95 of course) and is my daily use...
290MHz 2,5-4-3-5 1T only 2.6v with no active cooling on ram
http://www.crespo80.altervista.org/cesare/tccd290.jpg
what kind of ram?
it's written in the sandra screenshot:Quote:
Originally Posted by FlyingHamster
centon advanced (very very good ram)
EDIT:
chip Samsung TCCD-507
pcb Brain Power 808
but this goal was achieved by setting all the parameters in BIOS and testing them with the hardest memory test program, goldmemory 6.64.
If i clock in Win with clockgen and test only with superpi 32mb, i can achieve higher frequencies...
later i'll try with active cooling on ram (a simple fan), because now this is the limit, they aren't 100% stable even if i raise freq by only 2Mhz...
and increasing voltage to 2,7v has no effect, resulting in little worse results
:eek:
What's the board? DFI Ultra-D or SLi? Or something else?
Yes, GoldMemory 6.64 is a really nice tester, seems much better than Memtest1.55 and on par with "Memtest for Windows" :)
Also, is that Centon PC3200 Gemini LL ???
3700+ San Diego
DFI NF4 Ultra
OCZ 3200EL Platinum Rev.2 at 2.7v
Powerstream 600
http://img242.echo.cx/img242/9388/9x305pi1m3kk.jpg
http://img242.echo.cx/img242/9219/8x305pi32m4kh.jpg
Will try to get a 9x305 SPi 32m, still working with this SD.
the board is a DFI NF4 SLI-DR, now i have my config in sign ;)Quote:
the centon stick are "OEM", not sold in pair, I brought them from computersma of this forum.
They have Samsung TCCD-507 chips and Brain Power 808 pcb
I made several tests with practically all of the parameters in the BIOS, to find best settings for my ram. At a first time I worked so:
change a single parameter in BIOS and test with 10 runs of memtest #5
look how many errors it reports and choose the option with less errors
But when i repeated the tests with the same identical BIOS settings I obtained very different results (like 200errors VS 100 with same settings!!!), so I left memtest ang gone for goldemmory.
With this tester i obtained very precise results, and if I repeat twice a test with the same BIOS settings, the max difference, in terms of errors, is for example 205 VS 200.
So, for every single parameter in BIOS I made a full goldmemory pass (about 35min) and choosed the option with less errors.
Some settings now are different from the screen i posted (like the tRAS from 5 to 7 and the tREF from 3072 to 2048)
At a first moment i followed the guide from KAKAKOTO and ONEPAGEBOOK but then i went on my own
219x12 on some old ch-5. can do 235mhz with the same timings but the cpu doesn't seem to like it right now. still doing some tweaking. hope to be back with air cooled 2.7ghz+. here's the screenie.
http://img239.echo.cx/img239/9707/w3...rest0qe.th.jpg
this was with a DFI UT 250gb and a 3400+(NC) week 0503
Here's my GSkill LE at 300. Not 2.5 3 3 7 unfortunately, but other timings are quite tight. Also stable to memtest for Windows for 8 hours (at which point I decided it was stable ;) )
http://img33.echo.cx/img33/5437/gski...arks3se.th.jpg
Uh, this is for TCCD only :stick:Quote:
Originally Posted by omga14
@crespo, CTKP and uranium
Thanks guys :toast: Listing updated!
Also, CTKP to be the first one here to add his San Diego to the list :thumbsup:
@omga14,
yeah, sorry bro! at the moment we're gathering info on TCCD OCs only ;) but, maybe it's time to start another thread then... Hmmm :)
DDR632 9x316...32M may be a little slow cause I was surfing the web while it was running :p:
http://img226.echo.cx/img226/7934/mem4ez.jpg
Forgot to bring up voltages for the first screen shot :slap:
http://img226.echo.cx/img226/9749/volt1gf.jpg
SuperPI 1M just for kicks :)
http://img67.echo.cx/img67/6899/untitled2copy9pp.jpg
@Rubescen
I just added your 32M that I found here.
I was looking for some good TCCD clocks and tripped over your post. I hope you don't mind. If you get a better one then just post it here, please ;)
Anyone tried these? Are they tccd? :sofa: Check em out http://www.ocztechnology.com/product...fi_nf4_special
Yup..TCCDQuote:
Originally Posted by hangLewZ
:poke::rofl: :ROTF:Quote:
Originally Posted by Bachus's "title"
Sorry, couldn't resist...first time I noticed that little funny :p: In honor of your "title", may have something for ya this weekend bro ;)
:lol: Yeah! Since I have started to be known for bugging everyone I can for 16M/32M Pi, I bet they whisper that behind my back :lol:
You got some TCCD results for me? Sweet! Don't forget about BH-5/BH-6/UTT thread too, while you're on it :D You've been stockpiling those SpeedPremiums and Blues for quite a while now :stick: :p:
I get my OCZ 3200 Plat Rev2's on monday, i'll definetly let you know how it goes :D
Getting more TCCD in an hour. Along with a venice to play with. Results then :D
http://img140.echo.cx/img140/1488/ddr6203rg.th.jpg
TwinmosTwisterPro3200 TCCD 2x512mb :woot:
This is max SuperPi 32m stable Cpu Overclock with my 0437 winchester:
http://img140.echo.cx/img140/3135/2610stable6bv.th.jpg
300mhz 2.5-3-3-7-1T is memtest & 3dstable but not SPi 32m.
http://img140.echo.cx/img140/4697/8x300prime3bh.th.jpg
