haha, good point...Quote:
cascades power up and I can imagine it now, entire city's power grid goes down haha
As I said....I'll be watching the news. ;)Quote:
I think something like this happened in the past when they were experimenting with argon, but I'm not sure if it was because of a vacuum.Quote:
Originally Posted by gclg2000
Either way may the best man win, not sure who that is yet though.
EXTREMELY professional work by Chilly1.
I was curious.. Any idea on what the power consumption (approximately) of such cooling is?
Even ballpark figures?
Stephen
15/18 AmpersQuote:
Originally Posted by Stephen2
Holy miss moly detonator!
Your cascade is a monster...so glad it made it all the way in 1 piece too :toast:
Someone is going to be dropping abombs on the orb(s) soon :)
15/18 Amps? on 240V? LOL holly smokes BATMAN! lol
15 amps in insane
needs to groups or the power will fail when starting up :D
I assume that's the start-up power ?
chilly1 know:)Quote:
Originally Posted by Epsilon
:D Hey chilly - start a serial production to drop the price........., no - I'm kidding, perfect work and all I can say is that a VAPO or MACH is a children's toy compared to Your BEAST........... :toast:
I have a feeling someone is going to get #1 in the orb soon. Great Job Chilly! Detonater, give us some specs of what your are putting this monster on.
Actually it draws 12.6 amps at 230V 60HZ and I think somewhere aroung 15A at 220V 50 HZ
After all ther are 2 SC15 GXNO compressors and 1 Copeland 1.25 hp compressor..
Chilly1 > Hi, what's your CPEV pressure range ? Do you use cap tube for a pre-expansion before CPEV ? (generally CPEV have a pressure range of 0->90Psi, and 90Psi is not enough, probably.)
i believe the range is 5hg to 45psi. but he that is speculative.
what do you use to measure the current.Quote:
Originally Posted by chilly1
do you put a multimeter in series with mains cord?
detonator at the start chilly said it going on
a cpu, 2 cpus, cpu and video and an sli.
thats alot of evap blocks no wonder it draws 15A's
what pc gear its going on :slobber:
I got from chilly1 even the cpu/gpu container ,those are just great!!... we will do some combos with the 2 Heads... Friday and saturday, we made few runs to get confidence with the baby ....was funny,it's a beast... at almoust 3.600Mzr 2.0v the FX55 started 1 mega superpiii at the temp -94° droped just to 92° we were pretty shoked :toast: after 5 second at idle ,temp back to -94°Quote:
Originally Posted by kayl
any way, I will open a topic about, we got some nice scores to show:)
i can't wait any longer, i must see benchmarks.
This cascade will work on 2 CPU's, An SLI, A CPU/GPU, anycombo of two -100C heads you can think of.
Charlie the CPEV's I use have an input PSI Range of up to 450 and an output PSI of 5" to 90 PSI, Theat is the PArker, I also have some EATON A104's that are 5" to 45 psi..
I have some singer A2 that have 0-90.
thanks ;)
I use a field piece sc66 clamp on ammeter.Quote:
pure heaven on wheels :DQuote:
Congratz Detonator... Italy rulezz! :toast:
Go to WR... :thumbsup:
As insulation i use a wood like you for the mather board ,work just great;)Quote:
Originally Posted by k|ngp|n
New Guys are allowed one dumb question right. You are using constant pressure expansion valves in witch it has an orifice sized build inside CPEV's (Are they adjustable)?
To regulate gas to the HX or evap is that correct. Explain I am confused Just to many letter I guess I am use to old day TXV's were standard but really to big for this smaller systems
