Originally Posted by HARDCORECLOCKER
just wondering my bro,
you play those twtr and trtw setting see what happened? :D
try (twtr as 1, trtw as2 )compare with (twtr 2, trtw 3) ----> play with Sandra.;)
:D Yep - will try, not much experienced it because all my RAMs are single sided 256 MB.......... :toast:Quote:
Originally Posted by Onepagebook
I got 2x512, so double sided, I always set my drive strength on my dfi 250gb to 1, so say I move it to 2, what would happen (I'm using my kv8 pro right now as my temp sensor on the dfi is crap so I can't test it). But would it allow me to clock higher or improve performance or what? Right now my max with 3.6v is 265mhz 99% stable, all timings as tight as normal tight timings go, 2-2-2-10-7-12...Quote:
Hi OPB, great score!!!! I'm impressed! :)
I have some doubts, nothing special.
I noticed that your Dram was 3.96v but the 3.3v line was just 3.39. When I raise my vdimm to about 3.5 I set my 3.3v line in the psu to 3.7, is this correct?
Now for example I have 3.5 on the psu and 3.3 on the ram, and the 4x256 modules dont even get warm (all Bh5)! :)
Best wishes
Jorge Lopes
err hes using the 5v jumper on the dfi board, so the power to his vdimm is comming from the 5v railQuote:
Originally Posted by jll
ok thanks!
Didn't know that! :slobber: Always learning! :)
Bye
Randi:D,Quote:
Originally Posted by MrIcee
Long time no see indeed. I thought you were running at 4x multi actually. But let's not forget it was over a year ago and no one at that time could come even close to your sandra scores:) Those days i could only do 10x267 6:5 on Giga ES mobo and that was more than enough to get AMD back to the top of the ORB in '01 after like two or three years of Intel benching dominance. I was scared to think what you could've done with your OCZ ram, Shuttle mobo and a well cooled vid card....
Great clocks, congrats.
I really wonder what mine can do... I will get to know when I get my FX-55 (delaysdelaysdelays... ) :D DFI 's on the way, x850xtpe as well ;)
Nope, those mems do +270FSB with tights 1:1 on DFI nF2, DFI nF3 and hopeful on DFI nF4 too (shes coming tomorrow) :toast:Quote:
Originally Posted by TEDY
so the Vdimm does effect the A64 chip?!!? Damn I did not now this I only thought it was hard on the actual mem only!!Quote:
What is considered safe V then for 24/7 use using air??
Currently I am running my BH-5@3.1
/A
3.3v should keep you quite safe :)
I run 3.5-3.6v 24/7 with a fan on the memory, but I can't testify whether it's safe, just that I do it anyways lol
Well I don't care bout the mem atm - I was just thinking about what mrIcee said about the mem controller on the actual cpu!
I know 3.1 won't hurt my mem - but what about my cpu??
cheers
/A
haha I know your x850 xt pe is on the way though, I got one too.Quote:
Originally Posted by SAE
hey, thanks to Saaya. :D :banana:
i'd like to know, if 3,1 v would damage the cpu? i didn't notice anything till now :)
and btw! increasing the drive strength didn't change anything! i have the SAME sandra benches!
would should happen?
mfg
On the way?! Nicccce! :DQuote:
I hope I get it soon, so I can at least weigh it in my hands dreamin' of what could be with an FX :lol:
well if 3.6v dosn't hurt my memory controller, I doubt 3.1v is risking anything
same here, will have that tommorrow though,Quote:
I will try it on BH-5 as high as I can. :p:
Your 01 score will shine for sure!!! :thumbsup:Quote:
Thanks Master:D
here is the first try with 286fsb(BH-5)x11, x850 xtpe all air-cooled with 3d2001;), how do you think? I really appreciate saaya told me that cheap x850xtpe..haha, and more importantly, it rocks.. :D
nothing tweak, it's on the win2k3
Here is the official score link:
http://service.futuremark.com/compare?2k1=8419743
http://img208.exs.cx/img208/2369/x850xtpe013rj.jpg
wow
Great score for first run on air :thumbsup:
With a lil tweaking and higher card clocks (and higher Fx clocks under your cascade ;) ) you will definitely break 40k IMO. The hardware is able to do it as you are as well.
These fsb clocks on bh-5 make me even want my stuff more... :lol:
Damn, OPB :slobber: :thumbsup:
Superb clocks there!
When you get a moment can you do me a huge favour and try to run SuperPi 16M unpatched on it, plizzzz ? I'm very curious if you can get it below 10m00s...
Thanx,
BTW, what voltage is that BH-5 at?
yes, i helped sae to get an x850xtpe as well :DQuote:
your welcome! im glad it clock that nicely and you enjoy it!
have fun with it :) :toast:
btw SAE, i got a confirmation for the fx55 you wanted, next week ;) hit me up on msn :D
your welcome :toast: get some nice numbers out of it! that memory should be able to do more, make sure you use a psu wire for it that is not plugged to any other devices to it gets a clean and interference free cable directly from the psu! maybe the card needs more fresh air? what air temp is it there? i have seen 6600gt cards with 1.6ns gddr3 from samsung that did 1340mhz totally stock with even no heatsink on the memory! :DQuote:
maybe the heatsink on this card actually makes the memory get even hotter? maybe the heat from the overclocked gpu is transfaired to the memeory by the heatsink? try to overclock the memory without overclocking the gpu and see if you can get a higher overclock! :)
Wow on that 3d mark 01 score. That and who needs your x-files ram when you have bh-5 that will do speeds like those in that shot above. 2-2-2-4 at that speed (and stable) is nuts.
