Originally Posted by HARDCORECLOCKER
No, we're talking about ras-cas 4 :D
:confused: O.K. - You win and buy me a beer..............Quote:
Originally Posted by trans am
:toast:
Perhaps you´re using patched spi? On your rig is way more optimized?
I thought of that too, maybe HCC has better os tweaks and stripped down windows. I know OPB has gskill that does 2.5-3-3 at high speeds, but he was obviously checking to see how high he could get the dfi at 1:1 and not going for worlds fastest superpi. ;)
Yes that is quite obvious. :thumbsup: Either way its impressive (both results) :)
:D I'm using a fully installed version of WIN XP with SP2 - no tewaks into windows.
But heard about the advantages of using server2003 - is it true to get more performance and a higher OC ability with it ?
:toast:
there is nothing to do with 2003, you can do it on the sp2..
I got 24 secs and 9239mb/s..I think when I got cascade back from chilly 1, I can break my own record. :D
OPB
:D OPB - I cross my fingers for You and the 23sec............
But 24 is also outstanding, I saw many at 26sec - only a few at 25sec - but 24sec is hard to find !!!
But 25sec on stock single phase is also hard to find...........
Good luck mate !!!
:toast:
Onepagebook
Can this CPU overclock better on this board then on the others? ;)
Originally Posted by IvanAndreevich
you got the point!;)
My question too... perhaps my winnie will get a new breath in this board? (I had a MSI Neo2 before...)Quote:
EDIT: Sorry, but OPB was faster than myself :D . Didn't saw his post when posting mine...
Onepagebook
You never took the IHS from your chip either, have you? :)
is there any word on the DFI Lanparty UT Ultra-DR? The Ultra-D has just popped up on an aussie site here and i was curious as to why the Ultra-DR isnt even on the DFI website. If the Ultra-DR comes out the same time as the rest and has the same price difference as SLI-D to SLI-DR i want the Ultra-DR..
What are the differences between the SLI-D and SLI-DR anyway?
Is it only the extra SATA ports on the DR, and otherwise the pcb is exactly the same?
Why has the SLI-D the letters UT affixed to the name but not the DR?
Ivan,I 've never taken it out
Deuce..
DR---with Silicon image 3114
D without
OPB, What is the highest stable 1-1 HTT that you can do on the "mystery board" ;) at 2.5-3-3-7-1T at 3X and 4X if you would be so kind?
http://img.photobucket.com/albums/v13/smokin/DFI.jpgQuote:
Originally Posted by Deuce
Diagnostic LED Connector & FRONTX panel are for LANPARTY nF4 SLI-DR only.
LANPARTY UT nF4 SLI-D has the FRONTX panel ?? If this is correct. I think LANPARTY UT nF4 SLI-DR will have the FRONTX panel also
• LANPARTY nF4 SLI-DR
SLi graphics card bridge
UV kits(Round Cables & Cable sleeving bundled)
FRONTX panel
Four Serial ATA ports supported by the nForce4 chip
Four Serial ATA ports supported by the Silicon Image Sil 3114 chip
http://www.dfi.com.tw/Product/xx_pro...YPE=LP&SITE=US
• LANPARTY UT nF4 SLI-DR
FRONTX panel?
FRONTX panel?
• LANPARTY UT nF4 Ultra-DR
DXG(Dual Xpress Graphics) supported
lets see some overclocks with 2*512 instead of 2*256. Its more informative of the boards true potentials as most people run their systems with 2*512. 2*256 is nice and dandy for benchies, but not practical for everyday usage anymore unless u just browse.
do i need one of these "EPS" power supplies ? even when i start later using PCIe gfx cards ? or will a 20-24 adapter do the work for that time using my old pci-gfx card ? anybody knows
20pins PSU surely work with this MB, I tried... ;)Quote:
Originally Posted by psycho303
url not findQuote:
Originally Posted by bias_hjorth
EDIT : sh1t now I can see it
Can you try to overclock with a 20pin PSU, and a 24pin one? I mean, is there a difference in overclocking potential? According to the DFI techs I've emailed recently, these boards MUST have a 24pin PSU to work correctly.Quote:
Originally Posted by TinTin
:D O.K. OPB - if I get You right You say I can clock the same CPU higher when switching it from a NEO4 to a DFI.Quote:
Originally Posted by Onepagebook
So far so good - but whats the difference in bandwith between NEO4 and DFI if You compare both boards with the same settings, lets say 11 x 300 1:1, same RAM and RAM speed, same CPU and same cooling and voltages.
Run a SANDRA membench with both - will be important to see which board has the better bandwith.
:toast:
great news ! did you attached a 24pin adapter or just the 20 pin & good ?Quote:
what about the 4v vdimm with 20 pin psu, tried yet ?
thanks
YEAH!!! Hahaha - We want to see the 4V option and running off the 5V RAIL. You need to get Chilly1 to build a special cascade evaporator for the whole corner of the motherboard that gets hot! :) j/kQuote:
Hehehe - if you do that, could you video it, please?? That would make for some exciting footage for us xtreme peepz, especially if it starts frying. :slobber: :D :cool: :banana: :banana4:
