Originally posted by jinu117
V core vmod done successfully now. 50k 20 turn is in between the solder pad mentioned above and ground point. (Used one of 3 pin header so I can take it off on fly) The solder pad above is directly connected to pin 8. Haven't tried how far I can up the volt yet but sitting at +0.1v now and will start testing oc'ing now. stability seems fine at 1.8v (would be bios 1.85v) and stock speed.
UPDATE: Vcore mod is working just fine (heats up CPU nicely). However, my particular CPU was at end of its potential already so no voltage seem to matter unless some better cooling is in order (already on Koolance exos so only thing that will really eek out performance would be phase).
Didn't cost me anything and was kind of exciting to try :) BTW, a hint for some of you guys who keep case closed... :P You can cut the wire of those audio cable (extra ones) put it with switch and put it on PCI slot holder. Connect the corresponding part to CMOS jumper and voila, you got cmos reset switch right at back of your PC :P (been meaning to do this for months but never got around till today)
Did you soldered to the blue dot as shown on my picture a few posts back.:)
