i have the same on the right.
(left is dependant on the ram you use)
have a try with this (right)
2(with 1 you should get more performance - I can'T clock higher with 2)
3
4(I have problems with 3)
3
3
3
4
shouldn't give a big performance decrease but you should clock higher
tictac, You'll include Slew Rate and Strength in Tweaker ?!
I cant find CAS settings in WPCREdit
cas cannot be changed on the fly.
STEvil, i have some really good news :D
To change from CAS 2.5 to CAS2.0 you must change this Offsets
PCI Bus#0 Dev#0 Func#1 Offset#
Offset 71 = 24 to 04
Offset 75 = 24 to 04
Offset 9A = 76 to 65
Offset A0 = 6A to 2A
Offset A8 = 6A to 2A
Offset B0 = 6A to 2A
Offset F9 = 46 to 45
Note: Offset F9 must be the LAST offset changed
:D
looks like ima have to dust this app off since the 64 is dead...
So you kick a topic from 2004?
That's what I call a big bump, almost saurier like.
http://www.thorry.net/bumpasaurus.jpg
10-5-05...that was the last post...hardly 2004
That's because the thread has been bumped a couple of more times. The last actual post was in 2004. (10-24-2004)
It was then bumped on 04-12-2005
Then again (by the same person) on 05-06-2005 (after no reply being posted).
Then there were some reactions.
Then another bump on 10-05-2005 then some reactions and then this huge bump.
So the topic is a 2004 topic with a bumpy history :p
