Thx mongoose ;)
Thx mongoose ;)
now all you have to do is clock the card up enough to get on the first page so everyones buddie storm cant use that to tear down s939 newcastles anymore. Should be able to get 32k with a unmodded pro, seen 31k with less cpu power.
i want more ;) i hope 33 or 34K man :D
i had assumed that, but 570~580 core and 590~600 memory and your current cpu speed should be good for around 32.5k give or take or more. Easily do able on decent clocking 12pipe pro with the stock hsf. Not have'n seen a s939 newcastle at that tho makes it hard to say. similar card clocks and a 260x10 claw snagged 31k.
looking very good misterroadster :) 28.4k on a stock gfx.. jesus..
its a shame opp didnt bench his 3800+ with his x800, or at least didnt publish the scores. He got 3200mhz out of it didnt he?
No you haven't.:rolleyes:Quote:
save your bs for the kiddies:rolleyes:
http://service.futuremark.com/compare?2k1=7932196
TheForce's rigg.
Right! pkrew is having a tough time with 35k with the FX-53 and an XT, and you thought you'd get 33k with a Newcastle and a Pro unmodded? pkrew is no beginner. Who do you think you are, Macci?:ROTF:Quote:
loll , you can laugh :lol:
I'm just playing storm, testing to see the best configuration and nursing a sore back. I'll be over 36k before this is doneQuote:
Originally posted by StormPC
Right! pkrew is having a tough time with 35k with the FX-53 and an XT, and you thought you'd get 33k with a Newcastle? pkrew is no beginner. Who do you think you are, Macci?:ROTF:
Aren't we all just playing?Quote:
Well, you'll be at 36k before somebody takes an aircooled Newcastle to 34k, that's for damn sure. 36k on air? That's a pretty tall order.:lol:
Wont be on air, I'll be on OPP old gpu cooler, but possible if I put this spark 7 I have laying around and crank up the volts, but not likely. Certainly over 35k
You using OPP's old GPU cooler for the GPU or CPU?
so your saying people have done 34k all air on a clawhammer/sledgehammer/p4ee? since last time i looked everyone over 33k has PC or DI on at least there cpu. Last i checked pkrew nor misteroadster said anything about being on air. you really should be a little more consistant with whatever it is in your posts.Quote:
LS on the cpu, OPP's old cooler on the gpu. Should give me around 700/640 if the card clocks well. It got me 690/636 on a x800proQuote:
arf i got a poor X800PRO i think :
513/500 about for the moment :(
what do you think about ?
That's very bad sir.....
Check your voltages, maybe they are lower than usual. Cores have been reported as 1.3v-1.4v mem is usually 2.0v but I've read as low as 1.4v.
thanks oc-rookie ;)
Don't get your panties in a bunch JR. They knew what I mean't. Why didn't you? Something to think about.:rolleyes: :rotf:Quote:
http://www.vr-zone.com/?i=852&s=1
In case you haven't seen a good guide for the X800. GL :up:
Thanks homeboy, nice link.
You, OPP and I all from OC, eh? As counties go we're doing ok!:toast:
i knew what you mean't. just something about my nature that cant cut pompus :banana: :banana: :banana: :banana: :banana: :banana: :banana:s, who think because they have e-penis's the size of there 3dmark scores they can say whatever they like about other peoples hardware or there ability to overclock/tweak it, any slack. :toast: :rolleyes:Quote:
Seems so, gotta love the OC.
