ok yah i have the first tool, it says flaring tool on the box, so it must make flares :PQuote:
Originally Posted by cold_ice
do i need the second tool at all? or can i get by with just the first for joining tubing?
Make a pic from your flaring tool with the accessories, than I can say more about it. But normally you only can make flares with it.
ok, will do soon
do i need to get a swag tool?
You don't need it, but it's good to have one. A punch swag tool costs about 10$
I should look like this:
http://www.extremecooling.net/pics/1/1/werkzeug/19.jpg
guys i have a little problem with MAPP, it cannot make tubes red... :mad:
hold it close to the tubing, and heat up the tubing for like 20-30 secondsQuote:
Originally Posted by Malachia
Originally Posted by blinky
hem...heat up??? sorry english is not my best subject :p:
[italian help mode ON]
scaldare intorno al tubo, qui c'e' un altra brazing guide: http://www.jwharris.com/jwref/procs/
[italian help mode OFF]
if you need help my friend, you have only to call me.
Originally Posted by Dimas
:p:
Mapp vs. Propane is like night and day. I can't imagine O/A.
Mapp should do just fine from my experiance so far, I heated up an entire 3/8" to 1/4" brass flare union in very little time. I don't see the need for an O/A other then convienance.
I mean most of us are building DIY systems because we don't want to shell $500-800 on a vapochill/prommie. So a $200-600+ torch is usually out of the question. Guess I'll have to put up a mapp video one day.
i will built a statua (hem....things like the liberty one in new york :D) for youQuote:
Originally Posted by Newb101
:p:
i have a question.....dont laugh! - well not yet... :p:
is it possible that a better connection can be made if you had one part cooled and the other end hot?
you see in some manufacturing processes, they heat up one part of metal (so it expands) and have another peoce of metal (whic is cold and so contracts)
when they attach the ends together (e.g in railway wheels, the axle is cooled and the wheel is heated so when they put the two togethwr, they form a very tight fit)
so my question is - can this thing be done or applied to brazing of copper pipes?
and so get better connestions and less chance of leaks :stick:
now you can laugh :ROTF:
Thats a good question why would we laugh? I don't know the answer though sorryQuote:
Originally Posted by bxa121
i dunno, i guess i must have missed something glaringly obvious..
anyways i have another question...
copper is a good conductor right?
so why are we using it on the suction line?
wouldnt it be more appripriate to use a material that was less conductive (has to be brazable of course)
and if we had less surface contact with the insulator then there would be less heast loss through the insulator.
but im not sure,
if you have air in the spaces then you get water and eventually corrosion and stuff.. i dunno, just thinking...
Doesn't really matter. In series, you add thermal resistance. Theres no limit on how high you can get it by just adding more. So instead of looking at exotic and expensive materials with tiny increases in resistance, you can just choose the correct amount of insulation.Quote:
Its really just the thickness that counts, not the surface area. The surface is all at room temp, so theres almost no convection anyway. At least not if the insulation is good enough anyway.Quote:
but im not sure,
Where can a good Oxy/Acetylene setup be purchased and how much do they cost?
My Oxy/Acet Harris torch.
http://www.snt-systems.com/tommy/torch1.jpg
Here is one of my Brazes with 15% silver rod's
http://www.snt-systems.com/tommy/braze.jpg
And here is a nother braze.
http://www.snt-systems.com/tommy/braze2.jpg
Here is a full on flux free copper to copper braze that i did a few night's ago.
http://www.snt-systems.com/tommy/copperbraze.jpg
My torch was over $1000 with all the tip's and the cutting outfit, my oxy/fuel reg's were $200 USD a piece and all my tank's (4 acet 4 Oxy) i have about $500 in them. BUT u can get a good mickey mouse setup for about $300.
Originally Posted by KaptCrunch
With any setup it's better to have the flash guard's on the low side of the regulator....atleast that's what my book,and they told me for the past 6 year's while welding with Oxy/Acet Oxy/fuel system's and such.
In response to your question after that (didn't want to add the big quote), I don't know how you'd manage to keep one of the pipes cold inside the joint during brazing. In order to make a fit you could do that, but I'd rather grind the diameter down slightly. A fit that tight might not fill properly. But if not, you can heat up the outer pipe and when hot insert the other tube.Quote:
sell that might work for a decent connection but prolly wont hold anything near the pressure we are using. btw oxy-mapp is realy good. could i use a oxy-accetylene torch head on my mapp and oxy bottles? i dont see a problem seing as the misture is correct, iam just maing sure :D
A good rule of thumb is 1/4". Thats the minimum length of tubing you should ever braze inside the connection. If you've got a quarter of an inch, it'll hold. If you can't get at least a quarter... then I wouldn't use it in a refrigeration system.
Originally Posted by JSU
If it will fit then yes u can..Problem with MAPP Gas is u dont get verry much of it, for about $300 u can get a good Mickey Mouse Oxy/Accetylene cutting/Brazing setup and u wont have the need to preheat your evap's on a propain hot plate any more as the accetylene is far hotter then MAPP
mapp-oxy is within 300 degrees F of oxy-accetylene
http://bernzomatic.com/bernzomatic/c...parisons.jhtml
my mapp bottle has lasted me ~6 months, theres a LOT in each bottleQuote:
Originally Posted by BB mods's
