I used a very small wire(small fan wire about 24 - 26guage) from 3.3v line to vdimm circuit and came out with 3.16v for voltage..:D
I need to know the correct amperage of the vdimm circuit to be able to know the correct resistance... (
A 3 - 5 watt resistor is good enough if you plan on using the 3.3v line... If you wanted more vdimm than 3.3v you could use the 5v line, and a bigger wattage resistor... I will figure out the amperage and do the math for 5v line and 3.3v line..
Anyone know where to find variable resistors from 3 to 10watts very low ohms?
Anyone able to add to any of this?:D
